【Group Buy】SC31T Pro Anduril UI with Tactical Tail Switch
UPDATE Aug 30th
The Group Buy price will be 1x.99 USD
For those who are located in USA, you will get it on amazon where it will be available first.
I think it will be available in the end of September on amz.
SC31Pro has been a popuplar model of sofirn. More and more people love it. And there are always some people like it to has tail switch.
Now with gchart's help, I made it possible. I hope you are interested in this group buy.
SC31T Pro is enabling SC31T with Anduril. Furhermore, gchart helped adding "strobes" and "7 clicks to change indicator" in Simple UI.
For most common users or muggles like me, there is no need to bother doing 10H to Advanced UI when "strobes" and "7 clicks to change indicator" are available in Simple UI.
Would you buy one for yourself or to give as a gift?
How about a group buy? Are you in? Reply please, I will add you into list.
[Update Aug 16th] UI image for muggle to understand more easily.
Interest List
1. Skylight
2. SIGShooter
3. Zephon
4. Paul321
5. stephenk
6. Chinaheart
7. weklund
8. KgaBombadier
9. fluke
10. atobe
11. Unloco
12. fluke
13. shane1
14. VictorMarquez
15. alumenum
16. cannonball1000
17. Serlite
18. shirnask
19. johnnie
20.
I like the tail switch for lockout. Would it also have different colors, like blue, green or sand?
It’s not only for lockout, it’s also to switch it on and off. There is support for a mechanical switch in Anduril since the beginning (?), but it was never really used. I tried it once and it worked fine if you prefer a mechanical switch.
I wanted this 1.5 years ago. That’s why I modded my SC31 Pro with a Tail switch from the SP31V2. And adjusted Anduril.
Now she also has an SFT40. :sunglasses:
I’m interested depending on the price.
Question: for flashlights with tail switches, does the short tube work on it as well?
Am I interested in SC31T Pro? YES
I would buy one myself? YES
….fine print is that hope it’s available for purchase on my side of the globe along with door to door delivery….even without a battery.
Me too
Very interested - this could be very useful for light painting photographers. There is a lack of single LED, 18650 tube lights with Anduril and tail switch. Would prefer a throwy or high output emitter though such as SST40, or SFT40.
Which UI image is easier for muggle to understand?
Yes, if the black version is popular, Blue, Green, Red, Even Pink can be fulfilled in new batch.
I like this one best.
I have trouble understanding the other one.
Will there also be an "Advanced UI" on the SC31T Pro?
I would miss the calibration and adjustment features normally included with Anduril.
I do not have a SC31T but my understanding is that the SC31T has both an electronic side switch and a mechanical "forward clicky" tail switch (which allows "momentary on") and I also assume that the SC31T does "not" have an inner tube, so when the tail switch is OFF, there is not any battery power supplied to the side switch or the MCU.
What advantage would a tail switch provide for an Anduril version of the SC31T without an inner tube or would an inner tube need to be added to the SC31T when it becomes the SC321T Pro?
Or Is there something different with the MCU or Anduril implementation so that it remembers the previous operating state while the light is OFF so that when the tail cap is half-pressed or fully-pressed it can return to that state or would it just operate like a typical Anduril light (SC31 Pro) that only has an electronic side switch, where Anduril resets to the OFF state when the tail cap is loosened and re-tightened (whether the light is ON or OFF)?
What if the word “blinky mode” was replaced with “battery check” instead?
That’s all that 3C does, right?
That is a good point. For strobes to be useful for light painting photographers they have to memorised, which Anduril does by 5 clicks (5C) to engage momentary. Thus if this light is using strobes in simple UI, it either needs 5C for momentary added to simple UI, or use the tail switch (if 2 switch config) to turn memorised strobes on/off with a single click.
Interested also
Thank you for telling. Will modified the picture.
Check this video for more details
Thanks for posting the video, but can you directly access strobe from off by using the tail switch?
I am definitely in … :slight_smile:
