What do I calibrate my dmm with or from?
6 posts / 0 new
tatasal
Last seen: 1 hour 42 min ago
Recently I got a new dmm (actually a clamp meter).
The new one consistently reads about 3 volts higher than my old one on an AC outlet, and also when I check on some of my lilos.
Now I don’t know which of the two is showing the real or just perhaps the “correct” reading.
Any ideas?
Edited by: tatasal on 08/17/2022 - 08:05
jeff51
jeff51's picture
Last seen: 12 hours 59 min ago
Where are you located?
Perhaps there is a member nearby who has a quality power supply or even just a known good meter.
Failing that, perhaps someone can send you a battery that has a known V for you to measure.
All the Best,
Jeff
gravelmonkey
Last seen: 3 min 21 sec ago
3volts higher on (220v?) AC really not that much.
3 volts higher measuring 3-4.2V liion is a problem!
Might be crappy connection/leads, can you swap the leads and retest?
Edit to add: are the batteries in both DMMs good? I’ve seen reports of weird voltage readings if the internal DMM battery is low.
jeff51
jeff51's picture
This. And also try swapping the leads.
And here is an article about how to make an inexpensive low V reference source.
The trick with the parallel resistors to increase accuracy is nifty.
All the Best,
Jeff
http://frankshospitalworkshop.com/electronics/diy-voltage_reference.html
FlashPilot
FlashPilot's picture
Last seen: 9 hours 52 min ago
To maintain certification, they usually need to be sent out to be calibrated annually. I have a friend who works as an aircraft mechanic and use his DMM’s or PSU’s to calibrate my own. Sometimes they need no calibration. Other times they do, regardless of how cheap or expensive the device may be. This works well for me, given the general level of precision I need. If I needed greater precision, Id send it out for annual calibration.
Henk4U2
Henk4U2's picture
Last seen: 2 hours 5 min ago
All the Best,
Jeff
THANKS!
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
