Are there any small cells that are not complete rubbish?
I’ve been having trouble finding decent small cells like 10440, 14500, 18350. The 10440 seem to be the worst. I have 2 new Vapcell 320mAh (green) cells and the IR is around 200mΩ on both of them. I bought them off the Aliexpress official Vapcell store. Their 14500 cells are around 150mΩ as are the Nitecore 14500. I’m not trying to rip on Vapcell because their purple 30T rewrap is excellent as is their G53 26650. I’ve given up on using my Lumintop GT Nano because it flickers after about 3 seconds on turbo and then turbo won’t work at all until I charge the cells again. Even after playing around with the charge termination current by varying it from 20-50mA, the end of charge voltage is around 4.10-4.14V rather than the 4.16V+ on other cells (depending on wear level of course).
I’m doing the testing with a SkyRC MC3000 and ZKETECH EBD-A20H and not having any trouble with 18650 or 21700 cells. They all seem to match the manufacturers datasheet specs but ALL the small cells seem to be terrible. I’m not expecting them to be of the same quality as cells from the A grade manufacturers but these all belong in the rubbish bin. Even dumpster diving for old laptops I still get 10 year old NCR18650* cells with 40-60Ω.
Are there any good cells in this size, or should I give up on lithium in that size and stick with lights that use alkaleak or NiMH?
I could always bring you in some Epoch 18350 and 14500 cells from 18650batterystore in the US with my next order.
Battery orders from China have to either be shipped in a flashlight or pay DHL to NZ.
I sell mostly the Convoy torches here in NZ but the offer is there if you can’t get anything decent into the country. Store is called Piercing The Darkness. I wouldn’t get the 14500 or 18350 I have on clearance, but the Epoch cells are very decent
I would buy an epoch 14500 from NZ if it was in stock and the postage wasn’t too crazy
HKJ tested the Vapcell 10440 and got better results. There’s also the Efest 10440. There are several good 14500 cells including Vapcell H10 and L10.
The genuine Tensai (silver/grey) or Enercig (made by Tensai in blue) TN18350 HP has 700 mAh and is capable of delivering 14 Amps (20C!), although not for long… :wink:
I use them in very small vape equipment and they are very good!
sofirn has a 16340 that apparently really is 800mAH
i think that capacity is fairly easy to find
wle
