FREEME ✌ Mateminco FT01 SFQ34 14500 & FT02 SFN55.2 18650 FL in Alu / Brass/ Copper Group Buy - ALIVE
Mateminco FT01 (SEP 2022)
SFQ43 1250lm 209m 14500 Lantern Flashlight Group Buy
Group Buy Price: from $30 (usual $39.99)
Freeme's Exclusive Coupon: 1TDNEW
Mateminco FT02 (SEP 2022)
SFN55.2 6160lm 346m 18650 Flashlight Group Buy
Group Buy Price: from $37.46 (usual $49.95)
Freeme's Exclusive Coupon: ITDNEW
Specification:
Product Name: Mateminco FT01
Brand: MATEMINCO
LED: SFQ43
Material: Aerospace Grade Aluminum Alloy
Mode: Low, Mid, High, Turbo, Strobe
Switch Type: Clicky Switch
Switch Location: Tail Of The Flashlight
Battery: 1 * 14500 Battery (Not included)
Max Output: 1250lm
Max Beam Distance: 209 Meters
Max Beam Intensity: 11000cd
Driver: Direct Drive Driver
Impact Resistance: 1m
Waterproof: IPX6
Weight: 78g
Size: 98.5mm * 43.5mm * 22mm(Length * Head Diameter * Body Diameter)
Product Name: Mateminco FT02
Brand: MATEMINCO
LED: SFN55.2
Battery: 1 * 18650 Battery (Not included)
Max Output: 6160lm
Max Beam Distance: 346 Meters
Max Beam Intensity: 30000cd
Waterproof: IPX6
Weight: 118g
Size: 118.5mm * 51.5mm * 25.6mm(Length * Head Diameter * Body Diameter)
Operations:
Action OFF ON
Click ON OFF
1x Tap No response Moon (default) -Low-Mid-High
2x Tap No response Turbo
3x Tap No response Strobe
Memory None
Package included:
1x Mateminco FT01 Flashlight
1x diffuser
1x base
1x pocket Clip
2x O-rings
1x instruction manual
1x lanyard
1x Mateminco FT02 Flashlight
1x pocket Clip
2x O-rings
1x lanyard
Images:
Reserved.
Nice. CCT, CRI for the FT02?
SFN55.2 is cool white my friend.
Is strobe hidden or part of the direct ui? I will buy if hidden
On my FT01 it’s 3C from on to get to strobe That’s pretty well hidden for me.
I can’t say for the FT02.
Consider it purchased
Triple click after light is being turned ON. Not exactly well hidden but close enough i guess.
All replied.
code please
https://1thedeals.com/2022/09/mateminco-ft01-ft02-flashlight-group-buy/
MATEMINCO FT01 NICHIA 519A is in the plan.
I wish there was a 21700 version of this light. (Or 26650/26800, although I realize that’s far less likely.)
Releasing soon.
