I do the calculation in Excel. The calculation is not complicated and can be done directly in Excel.
Put x value in A2 and y in B2.
Put the following duv formula in C2
=SQRT(((4A2)/(-2A2+12B2+3)-0.292)^2+((6B2)/(-2A2+12B2+3)-0.24)^2)-(-0.00616793ACOS((((4A2)/(-2A2+12B2+3)-0.292))/(SQRT(((4A2)/(-2A2+12B2+3)-0.292)^2+((6B2)/(-2A2+12B2+3)-0.24)^2)))^6+0.0893944ACOS((((4A2)/(-2A2+12B2+3)-0.292))/(SQRT(((4A2)/(-2A2+12B2+3)-0.292)^2+((6B2)/(-2A2+12B2+3)-0.24)^2)))^5-0.5179722ACOS((((4A2)/(-2A2+12B2+3)-0.292))/(SQRT(((4A2)/(-2A2+12B2+3)-0.292)^2+((6B2)/(-2A2+12B2+3)-0.24)^2)))^4+1.5317403ACOS((((4A2)/(-2A2+12B2+3)-0.292))/(SQRT(((4A2)/(-2A2+12B2+3)-0.292)^2+((6B2)/(-2A2+12B2+3)-0.24)^2)))^3-2.4243787ACOS((((4A2)/(-2A2+12B2+3)-0.292))/(SQRT(((4A2)/(-2A2+12B2+3)-0.292)^2+((6B2)/(-2A2+12B2+3)-0.24)^2)))^2+1.925865ACOS((((4A2)/(-2A2+12B2+3)-0.292))/(SQRT(((4A2)/(-2A2+12B2+3)-0.292)^2+((6B2)/(-2A2+12B2+3)-0.24)^2)))-0.471106)
I know the formula looks ugly and not elegant,but it works well.
Once you verify the calculation, you can copy and paste the formula to next to the columns of cie x and y.
The formula is direct conversion of the code from waveformlighting.com website. Calculate Duv from CIE 1931 xy coordinates | Waveform Lighting
u = (4x) / (-2x + 12y + 3);
v = (6y) / (-2x + 12y + 3);
k6 =-0.00616793;
k5 =0.0893944;
k4 =-0.5179722;
k3 =1.5317403;
k2 =-2.4243787;
k1 =1.925865;
k0 =-0.471106;
Lfp = Math.sqrt(Math.pow((u - 0.292),2)+Math.pow((v-0.24),2));
a = Math.acos((u-0.292)/Lfp);
Lbb = k6Math.pow(a,6) + k5Math.pow(a,5) + k4Math.pow(a,4) + k3Math.pow(a,3) + k2Math.pow(a,2) + k1a+k0;
Duv = Lfp - Lbb;
Here are my measurements with Opple 3 and calculated DUV using the Excel formula.
!https://i.imgur.com/JvdHonC.png!
Edit: Text format alters the formula, so I change the format to plain text.
Thanks for sharing that excel formula. I tried to put it in C2 (A2 and B2 filled with X and y values) but excel gave an error. Would you be able to share the excel file?
Can you try this? There must be an error when copy and pasting.
