(Convoy) What's so great about an SS bezel, if it results in a bad beam?
Ever since Convoy started using a Stainless Steel bezel the horrible artifacts started appearing on the outer edge of the beam. I’m sorry, but I’m not into flashlight porn where I want a flashlight to look pretty on my shelf or to show the girls to compensate for something lol just kidding. Seriously though, I buy lights to actually use for their intended purpose, I absolutely hate a ringy beam profile. Every single Convoy model that has an SS bezel has an outer ring.
There’s a faint purple or green ring caused by the AR glass coating, but the bright white outer ring is from the SS bezel.
H3 & M21G = SS
Steel is stronger than aluminum, so if you drop your flashlight, and it lands on the steel bezel, there should be less damage than if the bezel were made of aluminum.
Also, the steel bezel is physically attractive, as you pointed out.
Far rather a dent than having to deal with a horrible beam I have to look at every night. I say, make it an optional accessory like it first started out as.
Its not about SS, its just badly engineered bezel, host, optics .
Well Funtastic...
You asked "What's so great about an SS bezel?" and I gave you the answer.
If you don't like the answer, that's on you.
Sorry bud, I meant visually when it results in a bad beam profile.
I realize that, but why ask the question when you don't want to hear the answer?
I'm wondering why people request an SS bezel besides the strength benefits. There's always so much complaints about beam profiles and tints, but SS bezels are still heavily requested, it's just so puzzling.
Oh, the bad beam profile doesn't bother me.
Yeah, it doesn't make much sense to request a stainless steel bezel and then complain about the beam profile.
That’s fine. I can’t handle moving the beam around and this bright ring is moving around with it. Hotspot > Corona > Spill > Black Space > Bright White Ring
I have a couple of other brands and it’s perfect as well :slight_smile: it’s just something that’s on every single Convoy model.
Sounds like Convoy needs to re-design their stainless steel bezels.
I mean, I love Convoy flashlights, but of course no flashlight is perfect.
IIRC, member JaredM did some mods to a Convoy M2 (SS bezel) in CSLNM1.TG which included blackening the bezel to reduce artifacts and raise candela. I don’t remember what his method was to accomplish that, but he stated that along with a black centering gasket made a significant difference in intensity and improved beam profile.
I jumped out of my chair and grabbed my M2 with SST40 and can hardly notice the outer ring. Maybe it has a lot to doing with the fact Convoy models aren’t designed for one set LED like other brands.
Because it makes this less likely to happen in situations where it matters:
Are you sure it’s the bezel causing the artifacts? On the couple i have (non-convoy)i don’t get artifacts but glare (which i realise is subjective).
I colour the inside of reflective bezels with black felt-tip pen, it’s not a perfect or permanent solution but it’s quick and cheap and reduces the glare enough.
May work for the artifacts?
I’m a Convoy dealer, so for obvious reasons I can’t start coloring in each bezel lol. I’m not a large enough store to request a custom version, so I’ve just had to avoid stocking every SS model.
It’s 100% the SS bezel causing it. I don’t get any artifacts with the Armytek Wizard C2 Pro Max, WR, and Nichia versions either
There are other means to this end. I use a black felt tip pen on my gaskets.
But it’s not a bad idea to blacken the interior part of SS (thrower) bezels.
Some guys using heat annodizing so steel reflections (artifacts) are reduced by a lot.
I’m simply use permanent marker and “draw” on inner side of the bezel where it’s in conntqct with lens.
a. subjective, i don;t think a ring is bad
b. aluminum would do the same thing
c. just get a magic marker and color it black [wasting lumens though]
d. i do need EDC ring to be strong, i drop them a lot, i have Al rings that have many dents
I did not remember the ring was there on the beam from my M21C-U. I notice it again now that you mention it. However, the ring goes outside of my field of view if the distance from the beam is more than 1 meter. Personally, I don’t mind it at all. Of course, added sturdiness is quite important especially the heavy ones. Heavy lights gets damaged way easily if dropped.
