Can't flash SP36, something wrong
5 posts / 0 new
Marios
Last seen: 1 day 14 hours ago
Hi all,
I couldn’t flash my sofirn sp36 BLF, can you help me please?
Using avrdude-6.4-mingw32
Quote:
C:\AVRdude>avrdude.exe -p t85 -c usbasp -n
avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update.
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude.exe: Device signature = 0×1e930b (probably t85)
avrdude.exe: safemode: Fuses OK (E:FF, H:DE, L:E2)
avrdude.exe done. Thank you.
C:\AVRdude>avrdude.exe -c usbasp -p t85 -U flash:w:anduril.2021-12-13.sofirn-sp36.hex
avrdude.exe: NOTE: “flash” memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option.
avrdude.exe: erasing chip
avrdude.exe: reading input file “anduril.2021-12-13.sofirn-sp36.hex”
avrdude.exe: input file anduril.2021-12-13.sofirn-sp36.hex auto detected as Intel Hex
avrdude.exe: writing flash (8076 bytes):
Writing | ################################################## | 100% 9.48s
avrdude.exe: 8076 bytes of flash written
avrdude.exe: verifying flash memory against anduril.2021-12-13.sofirn-sp36.hex:
avrdude.exe: load data flash data from input file anduril.2021-12-13.sofirn-sp36.hex:
avrdude.exe: input file anduril.2021-12-13.sofirn-sp36.hex contains 8076 bytes
avrdude.exe: reading on-chip flash data:
Reading | ################################################## | 100% 8.22s
avrdude.exe: verifying …
avrdude.exe: verification error, first mismatch at byte 0×0000 0×00 != 0xab
avrdude.exe: verification error; content mismatch
avrdude.exe: safemode: lfuse changed! Was e2, and is now 0
Would you like this fuse to be changed back? [y/n] n
avrdude.exe: safemode: hfuse changed! Was de, and is now 0
avrdude.exe: safemode: efuse changed! Was ff, and is now 0
avrdude.exe: safemode: Fuses OK (E:00, H:00, L:00)
Edited by: Marios on 11/24/2022 - 09:32
MtnDon
MtnDon's picture
Last seen: 21 hours 12 min ago
Have you been able to flash other drivers before this?
Marios
No, this is my first use of the USBasp programmer.
Same error when trying to flash using my phone
screenshot
MtnDon
MtnDon's picture
OK. I am not expert enough to be of much help. I have to refer to my notes every time. There could be many reasons. Let’s wait and see who else can help. Best of luck with this.
Marios
Thank you so much MtnDon,
I don’t know what fixed it, i just re-seated the clip and added “:a” at the end of flashing command… and it worked
the weird thing is when the flashlight is off the green led inside the push button is ON and vise versa… now i have to turn the battery cap to disconnect the battery and make the switch led off… weird.
Quote:
C:\AVRdude>avrdude -p t85 -c usbasp -Uflash:w:anduril.2021-12-13.sofirn-sp36.hex:a
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0×1e930b (probably t85)
avrdude: NOTE: “flash” memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file “anduril.2021-12-13.sofirn-sp36.hex”
avrdude: input file anduril.2021-12-13.sofirn-sp36.hex auto detected as Intel Hex
avrdude: writing flash (8076 bytes):
Writing | ################################################## | 100% 9.99s
avrdude: 8076 bytes of flash written
avrdude: verifying flash memory against anduril.2021-12-13.sofirn-sp36.hex:
avrdude: load data flash data from input file anduril.2021-12-13.sofirn-sp36.hex:
avrdude: input file anduril.2021-12-13.sofirn-sp36.hex contains 8076 bytes
avrdude: reading on-chip flash data:
avrdude: verifying …
avrdude: 8076 bytes of flash verified
avrdude: safemode: Fuses OK (E:FE, H:DE, L:02)
avrdude done. Thank you.
