Which version is better on the Lumintop GT Nano Pro, V1 or V2? Version 2 is without Narsil
V2 from Lumintop store has simple UI.
If you like ramping and you don’t like press and hold for 1 second for OFF then you would want V1
If you want a simple UI then you want V2
I have my Sofirn SP10 Pro set on the 7 step up ramping instead of the smooth ramping. I like the the step ramping better.
I don’t know which version has this.
This is from their AliExpress store
Operation Instruction:
General Modes: Low-Med-High (With mode memory)
Hidden modes: Eco, Turbo
- ON/OFF: One click the switch for ON, press and hold for 1 second for OFF.
- Output change: One click the switch from ON.
- Eco: Press and hold the switch for 1 second from OFF, another click will enter the general mode.
- Turbo: Two quick clicks from ON, another click will enter the general mode.
- Two quick clicks from OFF will enter high mode, another click will enter the general mode.
- Button backlit light ON/OFF: Continuously click the switch 7 times from OFF.
Thanks for the replies!
