SureFire Hellfighter
2) SureFire Hellfighter with Flip-up IR filter/cover
DC 12V, 3000 lm, 4300K
$ 450 or trade for Lupine Betty TL2S
I remember the Mr Bulk Lion Cub and Chameleon days I was first in line to pre order these cutting edge lights. :slight_smile:
C
Management and now they have quite interesting, only the diodes are old :slight_smile:
What power source does the Hellfighter use?
DC 12 Volt, starting current about 7-8 amps, steady state about 4-5 amps
price drop
price corrected
These are great prices for all items.
GLWYS brother
Price reduced on Hellfighter
Temporarily suspended the sale of MrBulk LionCub, since I got sad and I replaced the diode, I had to use some leather for the gasket, although the reflector was out of focus, but it turned out not bad, but it may be worth looking for a more suitable reflector or TIR that will fit in this head
I don’t know how many lumens there are, but according to the luxmeter, it turns out 2 times more lux at the same distance than the HDS 200 lm
LOL, now the reflector is melting, the diode itself is fine. I need an optic with a diameter of 21 mm and a height of 19 mm, heat-resistant, suitable for XML, has anyone seen one like this?
I have used McR-20 reflector on mine
I just looked through them a couple of minutes ago, the size seems to be more suitable for McR-19 and McR-19-XR. Where did you get yours?
McR-20 is 14.48 mm high, I need about 19 mm to fill the empty space with an additional layer of glass or make an additional plate of aluminum or copper and put it under the LED board?
Ah ok, you might be right. I need to check which exactly mod i did...
It was 3 yrs ago
Found, the aluminium reflector from the Convoy S2 S5 S6 S8 - D20.5 mm H19 mm fits perfectly here, but may need a small plastic spacer or kapton tape to keep the wires from shorting against the back of the reflector. Convoy - our saviors!
Any chance this is still for sale
