I want to test multiple big USB-C chargers. My plan is to trigger 20V voltage with ZY12PDN trigger boards. Then I need some load for these 20V… What shoud I use?
I was thinking of:
10W 4ohm cement resistor submerged in watter
or…
100W 4ohm power resistor mounted on some big heatsink
There are various, dangerous looking, fan+heatsink type ‘constant current battery testers’ on Aliexpress that might be of interest…?
Are you just looking for cheaper options than the resistors, or something ‘smarter’/’functional’? I’d have thought the 100W resistor option you mentioned in your first post would be the cheapest/best?
Running a 100W rated resistor at the full 100W ?? you have left No Margin and it won’t last long, and the resistance value will increase much more than the little bit of heat from 100W in the stove eyes.
The stove eyes are about 5 to 8 ohms, get a handful really cheap at thrift store (nobody wants them) then parallel to get the value you want if you are trying to be exacto. For load testing there is not any real need to have exact resistor values, you just want to load that thang down and see how long it survives. You can measure the current and voltage exactly. The device under test will heat up and have dynamic output too.
I really think you're best off with a CC load tester from Aliexpress. Do be aware that many are advertised with "Chinese amps" rather than "real" amps and will blow up or start a fire if you run them at their rated load. Unless you move to Siberia in winter and have a 5A Delta server fan blowing over it.
