Grizzly's NEW XTAR PB2S Review – Supports Protected 21700’s
Tue, 01/24/2023 - 18:02
#1
tactical_grizzly
Last seen: 15 hours 10 min ago
Edited by: tactical_grizzly on 01/24/2023 - 18:05
These are nice. Well done.
Did you do any resting to see what the charge rate is for the cells with any given charger (wall wart/supply)? Can it actually make use of PD 3.0 for input? I read the review a couple of times but if this was mentioned, I guess I missed it.
Related: Curious about how long it will take to charge the P42A that is drained to 3.17 volts for instance ?
THX
I did not test charging speeds. It claims to be able to charge at 2A per bay simultaneously, and that would require PD input to get the necessary wattage.
Reddit | Grizzly’s Reviews | YouTube | Convoy Guide
OK. THX. I guess then that it is plug and pray. No adjustable charge current? 2 amps is a bit hot for some of the 18650s that I use. It still is somewhat attractive for just the power bank functionality. Or maybe an occasional travel charger… with the right cells.
Anyway, thanks for the review!
I had a friend who used one of these sort of power banks to power a Pi. It had the “flaw” that when you plugged the power bank into an external charger while powering the Pi, the Pi would reset. So, I think it would pause power output for a few milliseconds when changing modes. Most of the time, my friend liked the “flaw” however, I could have used a unit that did not have this “flaw” and instead behaved more like a 5v DC UPS.
