Sofirn SC32 Review (Affordable EDC & Mini Tactical)
Welcome to my review of the Sofirn SC32, an affordable and powerful mini tactical EDC flashlight. This compact and durable flashlight is equipped with an SST40 LED, which provides a maximum output of up to 2000 lumens. It also features onboard USB-C charging, allowing you to easily charge the flashlight’s optional 18650 battery, giving you hours of use on a single charge. Whether you’re a professional, a hiker, or just someone looking for a reliable and versatile flashlight, the Sofirn SC32 is an excellent choice at a very affordable price. Thanks to Sofirn for sending it to me to review, and now let’s take a closer look at what this flashlight has to offer.
Don’t forget to follow me on my social media accounts for more updates and content like this.You can follow me on Instagram, TikTok, Facebook, and Twitter where I post behind the scenes and answer your questions. Don’t forget to subscribe here on Youtube so you never miss a new video too.
Watch this review on YouTube:
Follow me on Instagram: Jon (@liquidretro) • Instagram photos and videos
Join the Facebook Page: Liquidretro Gear & Reviews
*Follow me on TikTok: *liquidretro1 (@liquidretro1) | TikTok
Enjoy this review? Buy me a Coffee/Beer: https://www.buymeacoffee.com/Liquidretro
Find all my social media at liquidretro | Twitter, Instagram, Facebook, TikTok | Linktree
See my Amazon Store with my gear recommendations Liquidretro Reviews's Amazon Page
Links (Affilate)
Neutral White version Amazon.com Page Not Found Use code 10FXVQ6X for an extra 10% off for a total of 35% off with the coupon on the page.
Cool White Version Amazon.com Page Not Found Use code 15A3BS3V for an extra 10% off for a total of 35% off with the coupon on the page.
Packaging & Accessories
Sofirn has really stepped up the packaging here with the SC32. Instead of a generic brown cardboard box with only the company name on it, with the SC32 you get a white box with color photos and printing, as well as specs on the back. It features magnetic closure sides like you see on many Olight boxes for example, a real step up in quality, especially for the budget price these sell for. Inside the included accessories which consist of a lanyard, extra O-rings, USB-A to C Charging cable, and a manual are within another box to the side. An optional 3000mAh battery was included with my lights, and I recommend getting it as it’s only about a $2 difference in price.
Construction and Design
The light is made from aluminum and anodized in a more mat-black finish. One thing I immediately noticed was the difference in finish and Font between my two lights. The NW version I have is a more chalky finish and has the older Sofirn logo, the CW version is more of your traditional anodizing and has what I am guessing is their new logo in all capital letters.
The tail is glued to the body tube and features a flat recessed electronic switch with a big button pad in gray aluminum that’s grooved. I have zero issues with accidental activation here which is nice. The clip only attaches at the rear and is pretty tightly held on. The body tube has small fins milled in for good grip and a more premium look in my option than diamond knurling. Threads are raw, square cut, and well lubricated. This is a dual wall light to make that electronic switch work as well as onboard charging, and there is a spring on both ends of the light internally. One note is that there are exposed pogo pins (4x) on the rear of the PCB so this should be easy to flash the firmware on if you wish without disassembly needed.
The head of the light features the USB-C recharging hidden behind a silicone port that sits flush on what I will call the front of the head, with an LED indicator light to the side. The front of the bezel has short semi-aggressive crenulations protecting the plastic TIR lens.
Retention
Your retention options are simple on the SC32, The light comes with a generic lanyard that can attach on the clip. The pocket clip itself is the other option. It only attaches at the rear of the light, and is a dual-direction clip. It’s a fairly deep carry and has plenty of room to put onto the pocket of jeans. No major pain points here in my opinion.
SIze & Weight
The length of the flashlight is 100mm, with the diameter being 25mm. Weight with teh battery and clip came in at 3.72oz or 105.7g. The light is IPX water rated and here are a few photos of similar lights that I might have.
LED & Beam
The SC32 is using the SST-40 LED, It’s available in both cool white and neutral white which I have samples of both here. Cool white came in at 5772k at 63.8 CRI on my Opple meter, and the DUV had no unexpected tints. The Neutral White version came in at 4638k and 62.9 CRI with very similar DUV. I do notice with my eyes a bit more tint shift on the neutral white version of the light.
The beam in both lights passes through a plastic lens. Sofirn calls this a Fresnel lens, and what it creates is a more floody beam than a TIR optic. While it has a hot center it’s not very defined and spreads out rather quickly. Better for shorter ranges than longer distances which we will see in my night shots.
Outputs
I tested the outputs on my Texas Ace Lumen tube and most outputs were a little under Sofirns claim. As expected Neutral white was a little less output than the cool white version. My only concern was Turbo outputs were lower than claimed by a decent amount. I think the battery may be part of this issue and I will update if I find something different.
Heat & Runtime
I ran various heat and runtime tests with the two lights I had. Both of the batteries I received tested slightly above the 3000mAh rating. The NW cell was 3115mAh, and the CW cell was 3043mAh. With the CW light, total runtime in Turbo and High were very close between 5:15:00 and 5:20:00. Turbo saw the large step down after a 1:15. The light does have active thermal management that’s set to reduce the 55C (122F) to prevent issues. I did test this on the NW light and the highest I saw on the exterior of the light was 47C. The only difference worth mentioning between the two lights was the runtime on NW was slightly less at 5 hours total.
UI
UI here is very simple, long press from off to go to moonlight mode. Once on long press lets you cycle through the normal low, medium, high. Double-click when on to go to turbo and triple-click to go to strobe. The light does have memory mode.
Recharging
Recharging is accomplished via USB-C on the head of the light. The silicone port protector worked well, and stayed in place when not in use. There is a LED indicator near the port cover for voltage check and for charging indication.
LVP between my two samples averaged out to 3.0525V and charging time took 2.19:00 with max charging rate being about 1.6A. Charging stopped at 4.1V which is good.
Conclusion
Sofirn has stepped up their game with the SC32 in my opinion. The more premium packaging is nice and elevates the first appearance of the brand. They call this a mini tactical flashlight, but I would call it a great EDC option as well, due to it’s small size and easy UI. The one negative for EDC in a pants pocket might be the slightly aggressive bezel.
Sofirn continues to deliver great value here too, Before any sales you can order the light for $33 shipped with a battery at the time or ordering, and I am expecting to have a coupon for you to discount the price further.
I can fully recommend this light for the price here if you are in need of a new inexpensive EDC and want something that’s more on the floody side with decent power and runtime. It’s great to see LED tint options here. I would rather have tint options and low CRI like this light provides rather than an undesirable tint and high CRI.
Let me know what you guys think of the SC32 in the comments below!.
Have it, love it.
I always enjoy your reviews.
I regret not buying one of these when AliExpress had them for $20. There’s a lot to like here. Neither of yours seem to suffer from the green tint I saw in earlier reports. Maybe I’ll get another chance a sale.
Nice review. But its so strange that this sc32 is basicaly a 370lm light without stabilization and costs almost 30usd.
At the same time wurkkos wk03 and sofirn sc18 is 550lm light also no stabilisation but costs twice as low aroud 15usd.
An Anduril version would be great.
I think lights are more than just about lumens and price.
Lights are all about lumens candella stabilization tint and color temperature.
And such not cheap model as sc32 has driver even worse than the cheapest of cheap sc18/wk03.
