Review: Skyray King (3xXM-L - 4x18650)
256 posts / 0 new
how2
On the King does the Glass lens sit in front of the O ring?
Glass then lens "o"ring then reflector, can someone confirm this please?
Suncoaster
Suncoaster's picture
Last seen: 15 hours 16 min ago
Location: Where the girls are green and the grass is pretty.
On the black SRK, – Bezel, then glass, the O ring is behind the glass, around the reflector.
There’s another on the body, at the end of the thread.
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
skapri
skapri's picture
Last seen: 8 years 2 months ago
Hello everybody, I made two videos of this flashlight, bought 42€ (56$) including shipping cost :
Smile
skapri
skapri's picture
Hello, I bought Sanyo 2600mah batteries for my SkyRay King but I can't use it because they have a flat top...
Look this :
Someone has a solution to use these batteries in this flashlight please?
Thank you for your help!
Streamer
Streamer's picture
Last seen: 1 year 3 months ago
Hi. Some have used magnet 1mm x 5mm +superglued around outside edges +on positive anode of your flat top battery. Otherwise, buy proper battery.
scaru
scaru's picture
Last seen: 4 years 4 months ago
Or a drop of solder.
skapri
skapri's picture
Thank you for your help, finally I ordered Xtar 18700 2600mah batteries. Smile
Ramblings
Ramblings's picture
Last seen: 4 weeks 5 hours ago
Anyone know how waterproof these are? Big Smile
I have one. Trying not to drop it in a especially deep puddle as yet.
You are the light of the world. Like a city on a hill, you cannot be hidden.
People do not light a lamp and then hide it away, instead they put it where it gives lig
C-channel
C-channel's picture
Last seen: 1 year 1 day ago
Frankly speaking. I’m not too confident about the waterproofing. The threads are quite shallow on the front bezel. The glass is not tight enough to seal the front. However, I’ve not seriously tested it.
How bright is bright enough...
Runtime VS Lumens...
Pulsar13
Pulsar13's picture
King is not waterproof. The on/off button is not water-tight, water can seep in.
Ramblings
Ramblings's picture
Is this the only major flaw?
If I were to replace the switch with a water-tight one, would the rest of the internals be relatively safe?
I'm talking about just quickly dropping it into water and picking it back up quickly. Not diving or long-term submersion. Silly
Cheers.
lionheart_2281
lionheart_2281's picture
Last seen: 1 hour 1 min ago
I’m talking about just quickly dropping it into water and picking it back up quickly. Not diving or long-term submersion. Silly
Cheers.
I wish they made a SRK for diving…it’d be a perfect dive light
vēer
vēer's picture
Last seen: 1 month 1 week ago
I also have a question, well, two:
Given the sheer amount of lumens that it outputs, hows the throw compared to C8 thats driven at 1Amp?
Will King throw as far and will have huge-spill like hotspot or will it be much dimmer?
Also, is there a light for <50$ that is as good or even better than King regarding light output-power?
RedForest UK
RedForest UK's picture
Last seen: 1 year 4 months ago
Do you mean an XR-E based C8? It may not throw further, the C8 has a big head for an XR-E, but you will be able to see a lot more in the direction you point it.
The King can be had for around $40 now, there aren’t many excuses left not to get one Wink
vēer
vēer's picture
Yeah, Ive read plenty to see that it looks like a great light, I might get one depending how low the price goes during Wallbuys reservation sale :D!
Yes, its XR-E based C8, driven at 1Amp :D!
Well, if things are clearly visible at 100-150 meters/yards, then Id be very interested in it :D!
C-channel
C-channel's picture
Fast tech carries the Warm White version now. Looks like it is a hot sunny light!
http://www.fasttech.com/products/1601/10003058/1239701-sky-ray-king-3cre...
By the way, it was published with the details below. Doesn’t seem to withstand water like the experts had mentioned here.
Details:
Press the switch for 3 seconds to enter the “Rapid” mode
Ordinary waterproof function, can be used in rainy days
Working voltage: 3.6-4.2V
Working current: 2000mA
Mario999
Last seen: 5 years 10 months ago
Hi,
New on here but I’m after a light that is more a thrower for distance work. The crelant has the new u3 led and is designed as a thrower, but has less lumen output. This has maybe double the lumens, but is built more as a flood light. In reality, will there be much difference between the two? SRK is a little cheaper as well, which always helps. Any opinions welcome.
lionheart_2281
Mario999 wrote:
Hi,
SRK is definitely more of a flooder.
And FYI throwers normally have a lower lumen count, single LED and long reflector.
Check out the TN31, that’s probably the next thrower I’m getting.
Mario999
Just had a look at the TN31 and it looks fantastic, unfortunately it’s a little expensive for me. Could get 6 SRK for the price of the TN31. Is there anything else along similar lines but a little cheaper?
Guess my original question was, does the big lumens of the SRK almost cancel out the gains of a long reflector as in the crelant or thrunite.
lionheart_2281
No it doesn’t not even close, the SRK would be lucky to throw 300m, the TN31 can do 800m from what I’ve read.
Mario999
OK, thanks for the clarification.
Sirius9
Sirius9's picture
Last seen: 1 hour 24 min ago
Nightbird95
Nightbird95's picture
Last seen: 1 year 1 month ago
Thanx for this review. I ordered a Sky Ray King from Ali Express and the item arrived this noon – 21 days after I made the order.
http://www.aliexpress.com/item/Super-Bright-Sky-Ray-King-Flashlight-3-CREE-T6-LED-2-Mode-2000-Lumen-High-Power/705744446.html
I don’t know if this is the original SRK but I’m very impressed with the quality of its workmanship and the brightness of its beam. Its not as bright as my Black Shadow Terminator but it is floodier. More importantly, for the price of P39.99 w/free shipping, a budget flashaholic could never ask for more. Smile
DBSAR
DBSAR's picture
Last seen: 1 week 1 day ago
I recieved my new skyray King today, and wow its a real Retinaburner for its size. I will be doing a test comparison to my other big lights and beam shots as soon as the snow melts and it gets a bit warmer outside. :bigsmile:
FlashPilot
FlashPilot's picture
Last seen: 13 hours 36 min ago
The SRK has got to be the illumination bargain of the century for a flood light. With the 3 terroid driver version pulling 6.5A from the batteries, its driven hard enough to give 10 min of whitewall hunting, or 30 min of sustained outdoor use before becoming to hot to hold. Mounted as a bike light, it stays cool enough to run constantly in high mode for well over an hour before it starts to dim.
Far Thrower
Last seen: 4 weeks 1 day ago
I have bought quite a few Skyray Kings for family and friends over a long period of time and kept six for my own use around the farm, some Gold some Black, some older XM-L ones and some XM-L U2 ones as well as the cheap and nasty lookalikes that I have thrown into the bin quite a while back.
When you get the good ones they are just fantastic and the best ones I have had so far are the ones from Ric at CNQ. I was wondering if the King will ever go to the U3 LED. The XM-L U2 updated models have a noticable increase in the lumen output and it is a bit better in throw without loosing any real spill. More lumens and throw for the same old low price are always welcome in my collection. Another mode so that the light levels could be spread out a bit more would be handy to have. Has anyone tried modding the King with U3 LEDs?
Long live the King!
BLF ROCKS.
I think this question begs for a new post.
I have made this question a new post.
attitude
attitude's picture
Last seen: 3 years 7 months ago
any updateds on the kings ?
Maybe someone has to egg skyray on to make a U3 or L2 versions with better reflectors to destroy the TK75 Smile
best 65$ torch i ever spent , with panasonic 2900 mah and nitecore v2 charger all under 120$ kit Smile
weird i just get addicted to flashlight like in a blink of an eye.
DBSAR
DBSAR's picture
I am thinking of building the ultimate SRK that would give any torch a run for its money. Starting with 3 Luminus SST-90 big emitters, then a custom machined 4-26650 cell body or a longer 8-18650 body mod. J)
lionheart_2281
R3SET
Last seen: 7 years 6 months ago
Three of these https://illuminationsupply.com/cree-leds-c-52_36/cree-xml2-bare-u2-1c-ti...
all driven at 3A+
Davie
