Manafont C/S
28 posts / 0 new
2 DOGS
Last seen: 2 years 9 months ago
Manafont C/S
According to the
respond from manufacturer, the product should be function normally
without problem.
In case if you are not satisfied with the product, I'd glad to assist to
retrieve exchange on return. Thank you very much for your patience and
understanding.
Yours faithfully,
Audrey
Senior - Customer Services Team
Manafont.com        My first try at pictures        Cracked head on my new TF-1200 body  Threads are pretty sloppy + loose--- Manafont says it is still functional and does not need to be repaired This would be hard to sell and not a very nice gift. Plus it bothers me looking at it. What do you think I should do ?      exchange - points - partial refund - live with it
cracked
Chicago X
Chicago X's picture
Last seen: 8 years 7 months ago
The ano damage seems par for the course, but the sloppy threads would concern me if functionality is affected.
How much of a partial refund are they offering?  If it's enough, then you could possibly re-sell the light here at little-to-no loss.
Also, WELCOME TO THE BLF !!!  Please feel free to post up in the "Pet Thread" as well - there are a ton of animal lovers on the board.
http://budgetlightforum.com/node/6533
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
BetweenRides
BetweenRides's picture
Last seen: 3 years 5 months ago
True dat. Happy St. Pat's!  This is Bailey, my little Irish Lass.
2 DOGS
My picture doesn't show it very well but it's not bad ano but a crack thru the threads. The casting at the end of the crack is a little porous maybe a weak spot. The carton was nearly cut thru at the head probably from impact with something. Black makes the crack hard to see but on the top picture you can see light thru the edge
stevetexas
Last seen: 8 years 4 months ago
You deserve a replacement with no BS from Manafont.
Send them the URL of this thread.
We'll be watching.
aoyue2702
aoyue2702's picture
Last seen: 4 years 3 weeks ago
We'll be watching.
+1
2 DOGS
thanks stevetexas --- blems don't bother me to much, if they get used they get scratched but broken is different.  I'm using a DX 5X R2 drop-in -- maybe find it a new home in a 4D maglight. Only pulls 1.5 amps with 2 blue trustfire 18650's so it won't get too hot I hope
Langcjl
Langcjl's picture
Last seen: 3 years 9 months ago
We'll be watching.
I'm not big on returns\replacements for the minor stuff I see a lot on here but I have to agree with this. We will be watching, Manafont gets more than it's fair share of good press here. IMO not always deserved.
Piers said " ....but who wants enough light, when you have the option for far too much "
Foy
Foy's picture
Last seen: 6 years 9 months ago
I'm fast running out of patience with Manafont C/S right about now.
sixweeksFoy
No referral links and nothing embedded . . . ever.
                      &nbsp
fishinfool
fishinfool's picture
Last seen: 2 years 5 months ago
I just ordered a couple things from Manafont today and we'll see how things go.  I haven't had any problems with my dozen or so orders from them but that was all from last year.  My last order from them was Sep. 2011 so we'll see what happens with todays order.
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
keltex78
keltex78's picture
It took about 2 months and a lot of emails back and forth between me/CS/Jim before I got them to send me the correct drop-in I had ordered. Undecided It's obviously damaged though and would warrant replacement.
I wonder if the the CS team probably didn't read your email thoroughly or look at the pictures closely enough to realize that it was really a crack through the aluminum and thought it was just a scratch in the anodizing? I would recommend being patient and following up with another email. Is it possible for you to get a macro-shot of the damage with a strong backlight that can be seen through the crack to demonstrate that it does pass through the entire head? That crack would affect thread engagement and water tightness as well...
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
2 DOGS
My camera - its a Pentax optio P80- doesn't do macro very well (even on manual) shows dust good though. light isn't showing thru anymore I greased the o-rings covered the crack -- maybe if I boil it?
Foy
Foy's picture
If a light is crack(ed) you must send it back.
johnnycochranFoy
                      &nbsp
fnsooner
I had a similar situation with Manafont. I also had a couple of other items I wanted to order. I offered to submit my order if they were to include the replacement for the  defective item I had just received.
They agreed and I am happy with the outcome. I know this goes against the grain of some of the preferred methods, but sometimes you got to give and take a little.
I also must add that I think that your disapointment in the cracked host is perfectly reasonable.
2 DOGS
I've been e-mailing back and forth with M/F since 2/16 it's nice to have BLF support --- squeaky wheel and all.
r1derbike
Good luck! I don't purchase from Manafont any more.
I hope their CS has improved substantially!
soytnly
Last seen: 5 years 6 months ago
What happened to Manafont CS and Jim?  A year ago no one could touch them for the most part...seems after the BLF custom flashlight debacle it went downhill, and Jim more or less disappeared.  Just my observation, probably wrong Smile
Dave
Foy
Foy's picture
It's too bad if they have because that UltraFire 3-mode XM-L drop-in (sku 5720) is probably the best anywhere.
Foy
                      &nbsp
aoyue2702
aoyue2702's picture
Foy
I just ordered 2 of those a week ago at the same time I ordered my defective solarforce hosts.
They both shipped same day.
I got the solarforce hosts in the mail yesterday, so im hoping the manafont order will get here sometime within the next week.
2 DOGS
The order that had the broken TF-1200 body  also had 2 TF-3000 18650 flame batterys  and a 3 mode XML drop-in --- good as usual,  It's my 2nd (3rd?) M/F 3-mode and still the best.   And Ella is  Kiss
raccoon city
raccoon city's picture
Last seen: 18 min 51 sec ago
johnnycochranFoy
rofl
If they don't take it back, Manafont is whack.
2 DOGS
 Still no progress on the TR-1200   It looks like I can return the broken host on my own dime and they will replace it. Of course  I can't write chinese ideograms for the address and  my printer is long gone.  It's a good thing the price was only $13.00 for the host.  The body and tailcap are well made just the head and bezel are crap .  Spare parts for the box I guess.        >Hi Carl,
>Thank you very much for your confirmation.
>Attached with the returning shipping address. Please ensure the address
>and the order number are printed on the parcel. Please retain the
>receipt from you local POST office when you return the product, a
>tracking number is recommended to secure return shipping.
>You will be contacted by one of us in the team when the returned product
>reach us and verification of the returned product is completed. Hope we
>can resolve this issue for you as soon as possible.
>Please feel free to ask if you have more question.
>Best Regards,
>Jim
>Manafont.com
TadpolePilot
TadpolePilot's picture
Last seen: 4 years 5 months ago
On3/26/2012 ordered two item and am waiting.
Charger for 26650 and torch.
Hope to receive in a week.
Keep the e-mails going back and forth.
"Yell  {"Old, Broken Butt,  Zeide"}&nbs
TadpolePilot
Ordered a 26650 torch and charger on 3/26/2012.
sorry to hear of your problem.
Keep e-mails going and they will take care of them.
kreisler
kreisler's picture
Last seen: 8 years 3 weeks ago
Havent received a MF order (shipped Feb 14th, 2 months ago!!) so now i am finally testing their *service*: ive sent them an email (mail@manafont.com) ...
Let's note that sellers such as DD and HKE would issue a full refund (paypal, or giftcard) right away if the buyer didnt receive the shipment after such a long time. And no matter if the buyer had paid for insurance (2.00$ tracking number). it's their service (see also ebay sellers). Of course, the buyer is required to pay back the refund if the parcel still reaches the destination. Paypal dispute or claim isnt needed with such great sellers (DD, HKE, ebay). So let's see how MF C/S reacts to my e-mail inquiry...
*FMI* i got 4 i/o sh
pounder
pounder's picture
Last seen: 11 months 4 days ago
I already tried their cs and it wasnt until I filed a PayPal claim that they responded..all they said was you should have paid the 2$..I told them they should include it after 20 or 30$..got a message through my PayPal claim afterwards that said please wait for the package..I will wait until april 21 as the case closes on the 22..so if it hasn't arrived by then it will be a claim..
Not great cs in the least...
r1derbike
I quit doing business with these scumbags long ago.  Buyer beware.
jb1
Last seen: 9 hours 52 min ago
I ordered something on 03/15 and still nothing. They used to be the fastest shipper compared to DX and KD but now it appears they are just as bad. I'll start emailing them and get the runaround like the rest of you guys are getting I'm sure. Does anyone talk to Jim any more? He used to resolve issues in the past.
