X-Mods: FandyFire S3 Build/Upgrade
The FandyFire S3 definitely has its looks going for it. The stock internals are actually very good - the LED mounting area is an integral part of the head, as with the DRY.
While the XM-L with which the light was delivered was adequate, just enough is NEVER enough.
Thank goodness for copper.
The reason for the chamfered area is due to the ridge inside the head:
Below, one can see several details. I bored the inside diameter of the bezel ring to better accept the new optic, and added an o-ring groove. Also visible is the stock brass driver retention ring, which appears to be pressed in after soldering. This is a good design which I wish more manufacturers would adopt:
What is worthy of the copper, machining time, and removal of the awesome stock XM-L ?
Triple XP-Gs, that's what.
The stock host, less stainless bezel ring and tail:
The copper heatsink:
More to come, stay tuned.
Man you really need to mod a Xeno Cube and call it the X-Box.
I love the looks of the S3. Good job!
Part of why this S3 looks so good to me is because it somewhat resembles a Haiku. Classic design, for sure.
Foy
A stately budget
Springs from the most expensive
X makes it better
very nice. if this light was 18650 I'd order one right now...
I'm trying to avoid this size battery. This is the first time I've been really tempted.
How did you go about boring the bezel? That's a pretty delicate piece to put in a chuck...
Always fun to watch your builds Chicago. Are you going to remove the resistors and run the parallel or are you going to use a boost driver and leave them series?
I know, wait and see.Wink
Nice!
Did that with one of my older Longbows. Hack job heat sink though.
No machining tools really, really sucks.
Rich
Not sure I see the resemblance, perhaps the body is similar?
It's looking very similar to McGizmos McLuxIII
W, I can't wait to see the end result of this project. I love the look of that light but it is so expensive compared to others especially after modding it! I have 2 XP-G triples on deck myself and look forward to seeing how you are going to drive these.
You'd better keep some of that awesomeness in my lathe for me when it heads my way! ;)
@dthrckt: The bezel ring was the most fragile piece I've machined to date. After a bit of a read of "How to Run a Lathe," I cranked the speed up to 2k RPM and came in at a very shallow DOC.
@Tecmo: That haiku was awesome !
@Old-Lumens: I will likely remove the zero-res jumpers and wire it up in parallel. The single-cell format precludes the use of the boost drivers I have.
bet that was a little nerve-wracking!
What was the stock driver measurement? I'm thinking about modding one and was curious what I'm getting into.....
Thanks.
