Now THIS is big: Keygos? 7 x XML and 3 x 26650 IMR
Who will be the first one pulling the trigger?
The kit includes charger and 3x26650 IMR for 125 usd.
http://www.ebay.com/itm/8500-Lumens-7x-CREE-XM-L-XML-T6-LED-Flashlight-Torch-3x-26650-Charger-7T6-/280847906048
  • Emitter Type: 7x CREE XM-L T6 LED
  • Light Color: White
  • LED Quantity: 7
  • Power by :2 x 26650 3.7v / 2x 18650 3.7v / 3 x 26650 3.7v / 3x 18650 3.7v
  • Switch Location: Tail
  • 5 switch Mode: high / middle / low / strobe / sos <the worst modes on earth. I would like to know how much Amperes on high
  • Brightness: 8500 lumens <YEAH, SURE
  • LED Lifespan: 100,000 hours
  • Material :Aluminum
  • Lens: Coated Glass Lens
  • Reflector: Aluminum smooth reflector
  • Casing Color: Black
  • Size(mm):225 x 55.5(bezel)/26.5(body)
  • Weight: 400g
Size(mm):225 x 55.5(bezel)/26.5(body) >>> IMO 62mm bezel from original J12
5 switch Mode: high / middle / low / strobe / sos... (I do really love these modes )
that's awesome
light only is $95
I'm really wanting to try it, but something's telling me to let someone else jump first.
I don't recall how the trj12 driver works - but if the LEDs are parallel, i bet this is the same driver w/ different reflector.
if that's the case...ie it pulls the same current, then there's a bit more brightness at the expense of throw?
BUT - the KD 7xml driver might make this one hot potato!
Should totally trounce a TK 70, even if it's poorly driven.
uh oh - get your fire fighting suit on rusty
paisley shuffle fix
btt....again
somebody please buy this
I cannot get the measurements on the body/bezel to make sense. To me the head looks wider than stated.
Does anyone have some more information on this light??
This is annoying! Now they have 7 LEDs and it's gonna be difficult to resist, factoring that you can mod it with the driver from Kaidomain!!!
Wow. I wonder how hard they drive each XM-L? Most mega-leds Ive seen like this drive at a paltry 1.5 amps or so.
Very cool looking light and wouldn't mind having it myself. The one thing I did notice is the weight without batteries is 400g. Hopefully most of that weight will be for a very good brass pill. The pill on my Ultrafire UF-T70 weighs a whopping 230g. It would be nice if this light used as great a pill as the Ultrafire.
There needs to be a smiley of a jaw dropping, would be very appropriate here.
if this is the first 7 X xml, i think keygos trying to be a important brand like Ultrafire and trustfire with in chinese brands. Unless its not a false attempt to make this design :)
Very heavy and floody...I can pass, though I'd darn near pay to be there when one of you buys it and fires it up! :p
so we'll see 9xml (budget, not >$500) before....?....August
It looks just like the tr-j12 and i asked another seller about the + button's of the batteries and they said they do not stick out from the sides of the battery they might be like king kongs no good for series use with out mods ? ill wait for a trustfire version i think
I have a feeling that it is driven the same as the TR-J12. Coz it can use 2 x 18650 which is the same as the TR-J12. At such drive levels, there really is not much difference in OTF lumens between 5 and 7 XM-Ls.
Assuming it's the same driver as the TR-J12, is there a better driver available now that would make this light a wow factor type of light? (safely) Or do we have to wait until another company produces it with a better (new) driver?
