Now THIS is big: Keygos? 7 x XML and 3 x 26650 IMR
110 posts / 0 new
2100
Last seen: 3 years 2 months ago
1.75A at the tail (with the lousy cells so you are actually going to get higher than usual current anyway due the higher resistance) is pretty low with 3 cells.
IIRC, the TR-J12 is slightly above 2 amps with 3 good cells like XTAR 2600s....actually not the lowest resistance around here but decent enough.
df2dot
Last seen: 1 year 9 months ago
solowanderer
find an MMA or jujitsu class and get him to try some sports. also do what he can to avoid them , different camp or something.  being able to defuse conflicts is important too
i would not suggest try to sucker someone stronger or backing down either.
and if all else fails a ball peen hammer is useful. kidding of course
2100
gorann wrote:
Im not buying this, Im waiting for 10 XMLs
It's no use, the classes of 5 XM-Ls, 6 XM-Ls, 7 XM-Ls and even  10 or 20 XM-L showerheads would be the same output.
The limiting + deciding factors would be the drivers, which is directly influenced by the batteries. Dwelling into the drivers, it would be limited by the components' power (heat dissipation), hence size as well with regards to driver diameter as well as host-driver cavity size.
_the_
_the_'s picture
Last seen: 13 hours 29 min ago
oatmanutd / lumenhunter: How are the provided cells fitting in your lights? How long are the cells? What is the length of body tube in 3-cell configuration? Can you send a photo with all three cells in, without the tail cap?
(Lot's of questions, but please answer, so I know if I got a lemon)
=the=
benckie
benckie's picture
Last seen: 8 years 9 months ago
Would not mind more info on cells like IR, protected ? mAh and so on.
_the_
_the_'s picture
Ok, found the reason for cells not fitting. |(
Someone had figured that it would be fun to have two springs on top of each other:
..so I unsoldered one of them and now the cells are almost fitting (Read: If I fully tighten the tailcap, the light turns on! If I leave a 0.5...1.0mm gap, it works well.
And quickly I tried the ceiling bounce: The light is not as dim as I thought it to be. About in par with DRY Turbo of Skyray King (which is about 15% more than Skyray 3 x XM-L). And with that small current I would think that there are no thermal issues.. We'll see.
=the=
fishmaniac
fishmaniac's picture
Last seen: 7 years 2 months ago
So does this mean u are starting to like it?
_the_
_the_'s picture
Well.. At least I'm stopping to dislike it. Smile
=the=
Bizill
Last seen: 6 years 3 months ago
Awaiting your awesome pics, _the_.  They're the best.Laughing
benckie
benckie's picture
oatmanutd wrote:
I always get strange results from my equipment like 5.95A from J12 with 2 cells on high, so my reading is not reliable.
I got near on 7 amps with 2 x redilast 2600 on high with a cheap DDM ? cells not 100% charged will recharge and retest.
benckie
benckie's picture
What about this ot is a bit cheaper. and if you already have your own charger and batteries.
7 x T6
MarsFire B Cree T6 5000-Lumen 5-Mode 7-LED Flashlight - Black (3*26650/2*26650)
Or what about this one 7 x T6 cheaper again $77.91 shipped.
TrustFire TR-J18 Cree XM-L T6 7-LED 8000-Lumen 5-Mode Memory Flashlight - Black Aluminum Alloy Finish (3*26650/3*18650)
Good if you already have your own batteries and charger or want better batteries and charger.
nelg
Last seen: 9 years 8 months ago
Hi,
Just wondering if the  Keygos 7 runtime is much different from the TR-J12, and which one is preferred by people that have both?
I am also wondering about the SKY RAY L2 7xT6 Cree XM-L T6 8500,  just can't quite decide on if I should get a 8500 Lm light, or the TR-J12, which by the sounds of it is at least as bright.
http://www.lightmalls.com/sky-ray-7xt6-cree-xm-l-t6-8500-lumen-5-modes-s...
Any advise?
Mondosubmerso
Last seen: 9 years 5 months ago
I’ve sent off a couple of emails seeing if I can buy just the bulb. If it works as advertized, a couple of these would rock as DIY video dive lights in modified Maglite heads.
Has anyone seen an add or such for just the bulb?
Thanks,
Brian
AlexHH
Last seen: 2 years 2 months ago
I’ve got a question about this light: Does the Kaidomain driver fit in the lamp without any problems, or does it require some heavy modding?
~ carpe noctem ~
_the_
_the_'s picture
AlexHH wrote:
I've got a question about this light: Does the Kaidomain driver fit in the lamp without any problems, or does it require some heavy modding?
It's not a direct replacement. See here.
=the=
Mondosubmerso
I bought one of the lights. I got it without batteries as I plan to experiment with it as an underwater video light, i.e.; remove the tube and convert the head for use down to around 300 ft. Hooked it up to a DIY 17v canister light I built a couple of years ago. Dang, this thing is bright!
Only problem is the bulb diameter is considerably larger than a standard trustfire type light. Which means I’ll need to build a custom lighthead for it. But here’s the toughest problem so far: I can get the bulb out of the light. It’s either screwed in there really tightly or else it was soldier into place or something. Never had this sort of problem before. If anyone else has one of these by now, have you tried to remove the bulb and how did it work out for you?
Thanks,
Brian
Pharlap
Does any one want me to post pictures of the trj 18 knocking possums out of trees
We tested it at mates place lit up his back yard 40metrs cross the soccer field then lit up the big trees as clear as anything he said it would be great to bust the kids running around on field at night or blind them
_the_
_the_'s picture
Welcome to BLF Pharlap! You'll love being here!
Well of course. Feel free to share them!
=the=
AlexHH
the wrote:
It’s not a direct replacement. See here.
Argh, thats sad.
I really thougt of buying this light, but it is too much work for me …
~ carpe noctem ~
