I'm on the hunt for one myself. I understand you can charge a 26650 in an Xtar WP2 II with a little finagling. There's This on from International Outdoor Store, This from Feilong, This from HKEquipment, Trustfire charger from Manafont. Funny how many sites sell 26650 batteries and lights, but don't have options listed for charging them.
I use my WPII and a dime and nickel between the positive on the charger and the positive on the battery. Works great. Obviously this is a temporary thing, but in a pinch, a WPII and $0.15 is all you need.
I picked up an Ultrafire WF-188 as a "universal charger". I don't have any 26650's yet, but wanted to be able to charge them as well as 36650's (if I ever get those). Won't charge at a high rate (650mA max).
If you'd get this charger, you'd probably want to follow old4570's "mod" to fix the sliders contacts.
I have the Trustfire one. Its called the TR-005 on other sites. I had high hopes for it considering the relatively high claimed charging current, but after some quick tests I never saw over 500mA and once the light went green it was still trickling about 20mA into the cell. I need to test it further but itβs not looking good.
EDIT: the WP2 does work fine I just use a small magnet on the positive end to make contact.
It's a single bay, but since I only have one 26650 battery, I guess it'll do. Ordering today, hopefully I'll have it inside of a month... My Xtar WP2 II will also work in a pinch.
Hmm. . . only charges at 650mAh. That will be kind of slow. Decent looking charger though. I'm actually sitting here charging my 18650's at 650mAh and wishing it was faster!
True. Guess I was thinking 26650 size specifically. Wouldn't 650mAh be too high for 14500, let alone 10440? I'm liking the idea of picking up the Xtar WP2 (or perhaps that new Xtar charger just announced for release soon) which allows selection of 500 or 1000mAh.
Good charger Garry. I was wondering about the low charge rate (650ma) for 26650 as well. The specs for the Knot Top battery list charge rate as <= 1a. So I guess it's ok to use the Xtar to charge it.
Thanks for the tip, jonhobart! My Knot Top 26650 came today (probably 3 weeks ahead of my new single bay 26650 charger) and the nickel and dime approach worked, but it took a really long time at 1A charge rate. If you have them, 1 or 2 rare earth magnets on top work even better. I don't think nickel is a very good conductor of electricity.
By the way, I bought the TrustFail specifically to charge 26650 batteries and what a piece of junk it is. I still like it however, because it only charges to 4.18 volts. The Solarforce on the left consistantly charges to 4.24.
When charging 14500, Foy struts his engineering prowess thus . . .
Adjustable charge rate of 100-1200ma, full cc/cv control, thermal protection, input voltage of 5-12VDC. This is what I will be using with 26650's, the bigger the cell, the more important to have a safe charge protocol.
