26650 Batteries
364 posts / 0 new
taz
taz's picture
Last seen: 1 year 8 months ago
I also ordered 2x26650 Trustfires from Manafont, not sure where I'll get a charger from yet. I have a WF-139 for my other batteries but I suppose it cannot be used for the 26550???
Richie086
Richie086's picture
Last seen: 9 hours 3 min ago
Hi Taz, I really don't think using the Wf-139 is a problem to recharge the 26650s, afterall, many use their Pila charger to charge them too.  You'd have to use magnets connected to the 139's terminals, or create a couple of dummy 18650's and the magnets connected to the 26650's.
The thing is, it'll likely take quite a while to charge them.  The 4Stevens charger can manually be set to output 500mA or 1000mA, which is another reason I purchased it.  But the 4stevens is by no means the only solution for charging the 26650's.  Hope this helps.
Richie
taz
taz's picture
Using magnets is not a bad idea, I think I saw this setup somewhere, although I don't remember where. Does anyone have a quick guide on how to make them?
How much was the charger from 4Stevens? Do you have a link?
Richie086
Richie086's picture
taz wrote:
Using magnets is not a bad idea, I think I saw this setup somewhere, although I don't remember where. Does anyone have a quick guide on how to make them?  How much was the charger from 4Stevens? Do you have a link?
Taz, Here is the direct link to both items I purchased from them using coupon code, CPF8  I'm also a member of CPF, but I mainly like hanging on this forum much better.  Also, if you look around the internet, there are other dealers that sell the 4Stevens items for slightly less money.  But again, I used the coupon code for something like 8% off the total order.
Richie
taz
taz's picture
Thanks Richie!
cehowardGS
cehowardGS's picture
Last seen: 8 years 12 months ago
taz, you might have already seen this charger, but in case you haven't.. check it out..
http://budgetlightforum.com/node/9508
70+, Old, Dirty and Fast..
nekdo12
Last seen: 7 years 6 months ago
Solution for flat-top 26650
Little solder on + terminal.
viktori
viktori's picture
Last seen: 5 years 3 weeks ago
That's a really neat trick. Smile
This is my flashlight collection.
cehowardGS
Just got my two TF 26650s from DX. Took a while to get here, and they sent me the wrong items first. However, they made up for it and finally sent me the correct ones. I was in a spot with FIVE 26650 lights and only TWO Keygos 26650 cells. The Keygos cells work nice in my lights. However, after reading all the good reports here on the TF 26650, I placed an order with DX. Also, to back it up, I placed an order also with Manafont too..
Here are the ones from DX, and they look real real to me!!Wink
I put them in a light without even charging them, and they fired right up.. Happy camper.. Wink
Sparky
Sparky's picture
Last seen: 8 years 1 month ago
i have just ordered from DX too lets see how good they are.
How long did delivery take?
Richie086
Richie086's picture
Hey CehowardGS, Nice package you received there.  Glad they finally got you the correct items.  I just purchased the same cells from Manafont the other day.  The planets must have been in perfect alignment because they were shipped out in less than 24hrs.  Hopefully they'll get here in not to long.
Let us know how you like that charger, thanks.
Richie
cehowardGS
This was a resend because they sent me the wrong ones at first.
cehowardGS
I also got a pair of TF 26650s coming from Manafont too. Wasn't sure what DX was going to do, so I backed it with an order with Manafont.
On the charger, I have had that for a couple weeks now. Really good as far as I can tell. My protected Keygos 26650 fit right in there and the charger lets me know when it is finished too. Plus, it can charge any kind of rechargable battery. No 9 volts. It was $25 shipped..IMO, a good deal..
benckie
benckie's picture
Last seen: 8 years 5 months ago
If you want a good charger for 26650 its charges at 1.5 amps so it will charger alot faster then other chargers that charger from 0.5. 0.65 and 1 amp check out this link.
http://budgetlightforum.com/node/9437
bose301s
bose301s's picture
Or this which gives a 2 amp setting  http://budgetlightforum.com/node/6359
benckie
benckie's picture
Two amp,s might be a bit much even for 26650, you might start loosing mAh i would not charge 18650,s at 2 amps not even my 3100's, but i see a lot of people buying 0.65 amp chargers for 26650's 15 plus hour charge time lolls.
You want to charge them as fast as you can but not shorten the life and not increase the IR of the batteries, 1.5 amps is as high as ill personal go for 26650,s and i normally balance charge my 26650 at 1 amp, or use the linked charger when my hobby charger is busy doing other things.
garrybunk
garrybunk's picture
Last seen: 1 week 21 hours ago
I just received my Int'l Outdoor order from 4/17/12 with my King Kong INR 26650 raised top and (2) ML-102 chargers (ordered "INR" and received "INR").  These raised top cells do not like to sit in the ML-102 charger very nicely.  The raised top of the battery slides up off the positive terminal of the charger (because the terminal just barely hits the edge of the raised part).  Seems the charger is really sized for 18650's.
Anyone else using this combination?  Seems to me that for use with these raised top cells it would be best to file off some of the chargers rolled side (the way it's rolled to fit an 18650) to allow the 26650 to sit down lower.
Here's a photo trying to show the issue:
1
It's tough to see the chargers positive terminal, but you can see how the cell is raised up off the "rolled edge" of the side of the charger.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
Pok
Pok's picture
Last seen: 2 years 1 month ago
Garry, could you measure the length is?
garrybunk
garrybunk's picture
The length of the INR26650? Or the length of the charger?  Or both?  I'll see if I can get both tonight.  My calipers are metal, so what is the best way to measure the battery without shorting it?  Is a thin strip of paper sufficient?
-Garry
cehowardGS
I was getting ready to get this one ,but held up when I saw this. This is from Trustfire too, and it is a double bay for $2 more.. What you think?
http://www.manafont.com/product_info.php/trustfire-dual-channel-liion-battery-charger-for-2665025500267001865016340-tr006-us-plug-p-9985
viktori
viktori's picture
That charger looks pretty decent. Anyone have it already?
BetweenRides
BetweenRides's picture
Last seen: 3 years 1 month ago
Looks good to me, cehoward. As many 26650 lights as you have, I think you need a double bay at a minimum! I have not seen any reviews on this one, but Manafont seems to be a fairly reputable dealer of Trustfire. If you do go for it, report back with your impressions.
Richie086
Richie086's picture
Looks like this is the place to post this.
On Saturday May 5th about 1:00 p.m., I placed an order with 4Sevens for their 26650 battery charger and two 26650 4000mAh batteries.  At 1:00p.m. today the package arrived, wow.  I don't know if this is normal or perhaps I'm accustomed to waiting for packages from Hong Kong.  Either way, well done 4Sevens!
After looking everything over, I used my DMM to check the voltage of each battery and found them to be 3.75v each, basically exactly what I would have expected.  I tossed one into the 4sevens charger, flipped one switch from 3.2v to 4.2v and the other switch from .5a to 1a charging current.  While that one was charging, I tossed the other one into my Pila charger, which slipped right in, no fuss, no magnets and started to charge away.  Shortly thereafter when the light turned green on the 4Sevens, I popped the battery out and checked the voltage, which was exactly 4.2v.  Wow, I wish my Pila charged my 18650's to spec instead of 4.15v.
I checked the other 26650 on the Pila, and found it still charging and at 4.09v, removed it and tossed it in the 4sevens due to the slightly higher charging current and fantastic end voltage the charger achieves.
4Sevens boast their charger is optimized for their batteries, and I'd have to agree 100%.  Unless all 26650 chargers truly fully charge these batteries to their rated 4.2v without over-charging them, I'd say this was very good money spent.
A few photos of what I purchased, excluding the Fandyfire of course.
Comes with a wall wart charger, 12v cigarette lighter adapter, and USB charger cable for other devices.
After fully charging one, I placed it in my Fandyfire HD-2010, which swallowed it right up and fit perfectly, and checked the tail cap reading. It shot up to 3.6 amps on HIGH mode and continued to rise slowly up from there, so I disconnected my DMM. That same test using a Redilast 18650-3100 yielded about 3 amps. Man do these batteries pack some serious power. Now I know why so many of you love them.
I'm curious to see when my Trustfire 5000mAh 26650's arrive from Manafont soon, if this charger will charge them exactly to 4.2v as their own brand does, or undercharge them to some degree, or slightly over-charge them.  I'll have to keep an eye on it and let you all know.
Richie
cehowardGS
Yup, I might as well ordered this charger.. I just ordered another JM05 clone from DX..Couldn't help it.. That will put me up to SIX 26650 lights..Wink
Pok
Pok's picture
-Garry
The length of your raised top INR26650.
bose301s
bose301s's picture
My Xtar WP2 MkII charges my Keygos 26650s to 4.19v no problem.
Also, you need to mod the first post, the Keygos 26650s ARE protected, I can get pictures and post them if you want verification.
benckie
benckie's picture
cehowardGS wrote:
benckie wrote:
If you want a good charger for 26650 its charges at 1.5 amps so it will charger a lot faster then other chargers that charger from 0.5. 0.65 and 1 amp check out this link.
If it is 1 amp per bay it would be good, if it is 1 amp in total (0.5 amp a bay)  it still would be a lot quicker to use the single bay charger i reviewed.
At lest it too has a common power cord easy for us Aussie's to swap out, same for the guys in Europe And it looks like it has a female plug on the side for 12 volt cigarette lighter.
garrybunk
garrybunk's picture
King Kong Raised Top INR26650's:  Total length 68.05mm, diameter 26.33mm.  Battery is a tight fit in the ML-102 charger with just a mm or two to spare.  Here are photos:
1
Subtract thickness of the plastic disc:
2
3
Distance between contacts with no pressure:
1
Distance between contacts spreading as far as I can by hand (notice it's not even spread to the length of the King Kong yet):
1
With a 2400 mAh Trustfire Flame (cradled in very nicely):
1
I don't see any reason that I can't file down the rolled edges of the charger to better accommodate this raised top King Kong.  I can leave enough of the rolled edge to still firmly hold an 18650 (maybe file the edges down at the top and bottom to about the same level as the middle.
-Garry
garrybunk
garrybunk's picture
First use of one of my ML102 chargers.  Charged up my King Kong INR26650 and terminated at 4.19v measured with a cheap DMM.  I then disconnected from the wall adaptor and plugged in my iPhone 3GS to see if it would start charging and it didn't at first.  I removed the battery from the charger and placed it back in and it finally started charging.
Here's a photo showing my temporary solution to the raised top cell popping up out of the cradle (a rubber band):
1
-Garry
Boro
Last seen: 7 hours 13 min ago
1
-Garry
I was hoping for a less complicated solutionLaughing
