Drivers for SST-50 and SST-90 at DX!!!!!
4 posts / 0 new
fran82
Last seen: 9 months 2 weeks ago
SST 50 http://www.dealextreme.com/details.dx/sku.50025~r.43033281
- Model: TR-001PB
- Designed for Luminus SST-50 LED flashlight
- Voltage: 8.4V
- 5-Mode: High 4000mA, Mid 2000mA, Low 800mA, Fast Strobe 2800mA, SOS 4000mA
- Cable length: 7cm
SST 90 http://www.dealextreme.com/details.dx/sku.50026~r.43033281
- Model: TR-0124
- Designed for Luminus SST-90 LED flashlight
- Voltage: 12V
- 5-Mode: High 6500mA, Mid 2000mA, Low 800mA, Fast Strobe 5000mA, SOS 6500mA
- Cable length: 7cm
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
Edited by: fran82 on 11/28/2010 - 15:56
FlashPilot
FlashPilot's picture
Last seen: 1 hour 34 min ago
SST-50 Smooth Aluminum Reflector (5.1CM-Diameter)
SST-90 Smooth Aluminum Reflector (7.3CM-Diameter)
Now all we need is a cheap host to handle the massive drivers and reflectors. Anyone have any ideas? Also, the SST-90 driver might be a good choice for slightly overdriving an SST-50 for a mag thrower or similar.
fran82
I thing those drivers and reflector are designed for Maglites 4D or WF-500. (big head flashlights)
Don
Don's picture
Last seen: 10 months 3 weeks ago
I think the 7cm one is too big for a Maglite head - it is only 52-54mm inside diameter. The WF-500 is about the same, maybe a little larger. It certainly isn't 70mm. I don't own anything that would take a 70mm reflector.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
