Take a piece of making tape large enough to cover the PCB. Take a piece of plastic wrap and cut out a small circle about the size of the emitter with scissors. Place the plastic circle in the middle of the sticky side of the tape. Align the plastic over the emitter and stick the tape to the PCB. Trim with a razor to the outside of the PCB before you dremel. When finished grinding, peel off the tape. Done!
