Test / Review: Keeppower 14500 800mAh (Black)
24 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 2 hours ago
DSC_1522
Official specifications:
  • 14500 800mAh Protected Rechargeable Battery
  • Min Capacity: 750mAh
  • Typical Capacity: 800mAh
  • Normal Voltage: 3.7V
  • Quality Lithium Ion rechargeable cell
  • In Built Safety Circuitry
  • Maximum capacity and reliability
  • High Discharge Rate (Max 2C)
  • Protection Circuit (Against overcharge, over discharge, over current and short-circuit.)
  • 4.2 volts max voltage and 3.6-3.7 volts nominal voltage.
Keeppower%2014500%20800mAh%20(Black)-info
DSC_1521
DSC_1523 DSC_1524
DSC_1525
DSC_1526
Keeppower%2014500%20800mAh%20(Black)-Capacity
The battery has no problem keeping the rated capacity, even the 2A trace is very close to rated capacity.
Keeppower%2014500%20800mAh%20(Black)-CapacityTimeHours
Keeppower%2014500%20800mAh%20(Black)-Energy
Keeppower%2014500%20800mAh%20(Black)-PowerLoadTime
Keeppower%2014500%20800mAh%20(Black)-TripCurrent
Keeppower%2014500%20800mAh%20(Black)-Charge
Conclusion
There is not much to say about this battery, with a Sanyo cell inside and a protection at around 3A, I will call it a very good battery.
Notes and links
Keeppower is a OEM manufacturer, i.e. many of the batteries they produce is sold with other names on them.
The batteries was supplied by Keeppower for review.
Edited by: sb56637 on 08/26/2014 - 17:46
Langcjl
Langcjl's picture
Last seen: 3 years 8 months ago
It does look like a good battery. There is not much available in this category. Wish we know what brands used them and where they are available.
Piers said " ....but who wants enough light, when you have the option for far too much "
HKJ
HKJ's picture
Yes it does. I hope Keeppower has a plan with letting me test a lot of their batteries (more tests are coming) i.e. they will probably be available soon.
ezarc
Last seen: 3 weeks 3 days ago
Where can you buy these? I searched google without any results, only a few saying "min order: 100 pc" and still no price.
I am interested in some good 14500's to replace my TF Flame 14500's
Shadowww
Last seen: 45 min 5 sec ago
Considering 14500's are used in single-cell way 99% of the time you can use unprotected cell - which you can get in various places.
e.g. here: http://www.orbtronic.com/batteries-chargers/14500-sanyo-3.7v-840mah-li-i...
HKJ
HKJ's picture
And considering that most single 14500 lights has a boost converter (So that they also can work with AA batteries) that will drain the battery to below 0.8 volt, the unprotected cell is a bad ide in most lights.
Shadowww
Oh crap, I totally forgot about that. Thanks for reminding! Indeed, 14500-light with a boost converter would be quite unsafe to use with unprotected cells.
ezarc
I want protected ones so I dont drain them too low.
Any idea if they are available in singles or pairs HKJ?
HKJ
HKJ's picture
Sorry, but no.
Suncoaster
Suncoaster's picture
Last seen: 3 weeks 6 days ago
Location: Where the girls are green and the grass is pretty.
ezarc wrote:
Where can you buy these? I searched google without any results, only a few saying “min order: 100 pc” and still no price.
I am interested in some good 14500’s to replace my TF Flame 14500’s
I know it’s months later, but for reference I found these on an Australian ebay listing:
http://www.ebay.com.au/itm/2x-Protected-Sanyo-Panasonic-UR14500P-800mAh-...
I bought a pair and they’re labelled Keeppower.
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
Ualnosaj
Last seen: 7 months 4 weeks ago
We’ll have them soon too Smile They test extremely well, and rival the Nitecore 14500 which is our in-house king now.
HIDCanada.com for Fenix / Sunwayman / XTAR / XENO
Ualnosaj
Well, tested them and while they perform admirably, they are just too long to be considered. The lower capacity version is shorter but still can’t dethrone the Nitecore — and to a lesser degree the AW.
MarioSS
MarioSS's picture
Last seen: 6 years 1 month ago
Hey HKJ
I would like to ask you if you heard anything about the Keeppower DLG protected 14500 800mAh? how does it compare to the Sanyo cell?
HKJ
HKJ's picture
MarioSS wrote:
Hey HKJ I would like to ask you if you heard anything about the Keeppower DLG protected 14500 800mAh? how does it compare to the Sanyo cell?
Not yet.
KumaBear has talked about sending a couple of DLG batteries to me for test, so there is a good probability that I will be testing them.
The next 14500 I will publish a test for is probably the Efest IMR cells.
MarioSS
MarioSS's picture
Thanks for the clarification bro!
I guess they will be one of the best budget batteries for the price KumaBear is offering. Ill get a set to replace my 14500 Trustfire Flames.
Will be looking forward to see your latest findings 8)
keep up the great work Beer
Overclocker
Last seen: 3 years 12 months ago
at almost 53mm aren’t they too long for certain lights?
HKJ
HKJ's picture
Overclocker wrote:
at almost 53mm aren't they too long for certain lights?
It will be that, but remember that the light must be made for LiIon, before you can use this battery. It has the voltage of 3 NiMH in series!
Overclocker
hi henrik, yes i’ll be using them for Quarks and SC52.
the zebra ZL584 is just 52mm and is already protruding out of the Quark’s body tube slightly. i noticed that the ZL584 has a low-profile nipple
the keeppower seems to have a taller nipple
phantom23
phantom23's picture
Last seen: 1 month 4 weeks ago
They are waay too long for Nitecore D10. I have to keep using my old Trustfires.
CalvinIS
CalvinIS's picture
Last seen: 1 year 11 months ago
cat eyes wrote:
the keeppowers sold at illumination supply are not sanyos.... they are DLG.... which i was told by illumination supply is chinese.... i always thought DLG was korean, which would be ok with me..... but not chinese batteries..... makes me vomit
The KeepPower 14500s we carry were never advertised as Sanyo, and they are listed on our website as having a DLG ICR14500 internal cell. A Sanyo version does exist but we did not claim that our version is Sanyo.
USA based seller of flashlights, batteries, and chargers.
Illumn Webstore
 /// Instagram /// BLF DEAL THREAD
Overclocker
cat eyes wrote:
i also wish you had a protected 14500 with length 50mm and japanese cell
a sanyo BARE 14500 is already 49.4mm long Wink
Calmaja
Last seen: 2 years 4 months ago
cat eyes wrote:
and my question about chinese cells is :
how many recharge cycles will you get… ??
i say that chinese quality control is not as good as japanese quality control….
and that chinese cells will never have as many recharge cycles as japanese cells…..
and the extra money for japanese batteries
is money very well spent…..
I guess we won’t know for sure where those cells come from:
http://news.panasonic.net/archives/2012/0717_11435.html
http://gsminsider.com/2013/10/samsung-executive-blames-chinese-manufacturing-plants-for-bloated-batteries-of-galaxy-s4/
China battery industry 2010
89 300ce
Last seen: 6 years 6 months ago
Would it be possible to update this review?
“Conclusion
There is not much to say about “this” battery, with a Sanyo cell inside and a protection at around 3A, I will call it a very good battery.
HKJ
HKJ's picture
89 300ce wrote:
Would it be possible to update this review? "Conclusion There is not much to say about "_this_" battery, with a Sanyo cell inside and a protection at around 3A, I will call it a very good battery. "
There is not much point in updating this review, I will prefer to get a new battery from Keeppower with the new marking.
