Test / Review: Keeppower 18650 2900mAh (Black)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 23 hours ago
DSC_1451
Official specifications:
  • 18650 2900mAh Protected Rechargeable Battery
  • Min Capacity: 2750mAh
  • Typical Capacity: 2900mAh
  • Normal Voltage: 3.6V
  • Quality Lithium Ion rechargeable cell
  • In Built Safety Circuitry
  • Maximum capacity and reliability
  • High Discharge Rate (Max 2C)
  • Protection Circuit (Against overcharge, over discharge, over current and short-circuit.)
  • 4.2 volts max voltage and 3.6-3.7 volts nominal voltage
Keeppower%2018650%202900mAh%20(Black)-info
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
DSC_1451
DSC_1452 DSC_1453
DSC_1454
DSC_1456
Keeppower%2018650%202900mAh%20(Black)-Capacity
Keeppower%2018650%202900mAh%20(Black)-CapacityTimeHours
Keeppower%2018650%202900mAh%20(Black)-Energy
Keeppower%2018650%202900mAh%20(Black)-PowerLoadTime
Keeppower%2018650%202900mAh%20(Black)-TripCurrent
Keeppower%2018650%202900mAh%20(Black)-Charge
Conclusion
With a 2900mAh cell the battery is slightly below the highest capacity batteries on the market, but not much.
I will rate this battery as very good.
Notes and links
Keeppower is a OEM manufacturer, i.e. many of the batteries they produce is sold with other names on them.
The batteries was supplied by Keeppower for review.
Edited by: sb56637 on 08/26/2014 - 17:46
nekdo12
Last seen: 7 years 9 months ago
Do you know which names?
HKJ
HKJ's picture
Yes, but I believe it is up to the dealers, if they want to reveal their source. They are of course welcome to post this information in the relevant threads.
