BeamTech 4000 3x Cree (help, help & help) Warning long,pic heavy too
37 posts / 0 new
cehowardGS
cehowardGS's picture
Last seen: 8 years 7 months ago
Took me 25 minutes to post this up with pictures, and then the site went off line!! Got to do it all over again.. Cry
Quickly this time.. I got this BeamTech 3x Cree 1x26650 light from Tmart on special for $37.75 shipped. They ship out of NY, so I got it quickly. First off, the Customer Service at Tmart, IMO, on a scale of 1 to 10, with 10 being the best, they are a 25!! easily..
I ordered this light about 3 weeks ago from Tmart and took their special of $37.75 shipped. The light came in a few days, because they ship out of NY. I took it out the box, and it is indeed a handsome light. Workmanship, from my newbie eyes, good to very good, maybe excellent. I put in a Keygos 26650 cell, and oh boy. A real nice flood/beam, perfect for my bicycle application. I played with the light half the night.. The next day, go to get the light, no workee??? I did everything.. Took it apart, changed batteries, still no workee..
I email Tmart, they apoligized for the inconvience, and told me they would send me a return label to return it, and they would send me another or give me a refund. I opted for another light as I do like the light a lot. A few days later, the second light arrives. It works.. It worked for couple days, then back to the SAME THING. No working.
On another forum, a poster has the same light, they told me their light didn't work out the box, and they fiddle around with a spring and it has been working everysince. Okay, I take my newbie eyes and go look for this spring. I find a spring loose right behind the pill. I move it around, tighten everything back up, and the light works. I figured I had the problem solved.
The next day, I am riding with the light securely mounted on my bicycle. I roll over some rough ground or hit a bump, the light changes modes on its own!! Then when I got back home it stopped working completelly.  I let Tmart know, and they again sends me a return label to return the light.
Here the situation, the behavior of this light is unacceptable, period. However, I do like this light very much. I figured if I post the pictures of this mystery light, showing the spring in question, somebody can suggest a fix that a NEWBIE like me can perform. That way I can keep the iight. Other than that, I will have to send it back and get a refund. Check all the pictures, and I do point out the spring, and show where it goes.
Thanks for looking...
70+, Old, Dirty and Fast..
cehowardGS
Another picture I forgot..
garrybunk
garrybunk's picture
Last seen: 3 days 11 hours ago
Sounds like the battery is losing contact (momentarily would cause the mode changes like using the switch).  I don't have any recommended fixes though, so I'll let others chime in.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
BetweenRides
BetweenRides's picture
Last seen: 2 years 9 months ago
I think the spring should be soldered - is the solder point broken or was it never so? Sounds like it's working loose.
I've only had a loose spring once and that was on a P-60 drop-in. I just put it back in place and it worked fine.
kramer5150
kramer5150's picture
Last seen: 5 days 13 hours ago
Lots of loose parts "floating" in this assembly.  That big spring looks suspect immediately.  I would guess its creating an intermittent contact with the body tube.
Double check the tailcap guts too, make sure the tailcap pill is not loose.
Richie086
Richie086's picture
Last seen: 17 hours 39 min ago
To use that light on a bicycle, you're going to have to solder that spring in place without doubt.  If you can't do it, perhaps you know a friend that can.  If not, you'll have to return the light for a refund.  If not used on a bike, likely it would be okay not subjecting it to such vibration.  Hope it works out for you.
Richie
BetweenRides
+1
I agree with Richie, cehoward. On my P60 drop-in, the spring is a verrrrry tight fit and it is held in place firmly by the collar below the pill. How easy is it for you to pop the spring loose? If it is always loose, it will never work properly with any vibration or bumps, especially with cycling.
JohnnyMac
JohnnyMac's picture
Last seen: 1 week 21 hours ago
BetweenRides wrote:
+1
+2
I agree with Rickie & BR. Easy fix if you can solder.
kramer5150
The problem here guys is its darn near impossible to solder anything onto Aluminum.  I have ditched/scrapped DIY projects mid-stream because I could not get solder to flow on to Al.  OP I think you might be able to solder the spring onto the brass pill on one end, but the other would need to make touch-contact.  If you could DIY fabricate a copper or brass ring, press that into the throat area of the light and wire-connect the pill to the ring with solder I think that would be better.
Side note... IMHO springs that are used to bridge large gaps are generally a bad design.  The only time I see them advantageous is with Incans, where heat conduction is not an issue, and they need some degree shock-impact isolation.  Just the other day I had to fix a poorly designed tailcap that used a spring to bridge a gap between the retaining ring and pill guts.
JohnnyMac
JohnnyMac's picture
I hear what you are saying about soldering to aluminum but if you look closely at his pictures you will see what appears to be a brass exterior to the pill that is several MM wide from the driver to the aluminum heat sink.  He should be able to solder the spring to the side of the pill.  It sounds like the spring does not fit tightly around the pill walls like on a P60 design and that's where the break in connection is occurring from vibration. My thought is that just making the connection from the front end of the spring to the pill with solder should resolve the issue.  I don't have this light so I could easily be wrong about it's construction but from what I can see it looks possible.
kramer5150
I hear what you are saying about soldering to aluminum but if you look closely at his pictures you will see what appears to be a brass exterior to the pill that is several MM wide from the driver to the aluminum heat sink.  He should be able to solder the spring to the side of the pill.  It sounds like the spring does not fit tightly around the pill walls like on a P60 design and that's where the break in connection is occurring from vibration. My thought is that just making the connection form the front end of the spring to the pill with solder should resolve the issue.  I don't have this light so I could easily be wrong about it's construction but from what I can see it looks possible.
Yeah the pill-end of the spring probably could be soldered.  Although that might not be necessary, if its firmly attached to the pill by its own force exertion.  Its the other end that looks more more troublesome, with a larger gap to bridge over.  The OP might be able to bend the spring to get it to contact both ends reliably.  There are some more detailed pictures of another members light in this thread here...
http://budgetlightforum.com/node/3157#comment-112576
cehowardGS
What I have in bold is exactly what I told Tmart. Their customer service is top notch, but this is just a poorly designed light. I don't know how to work on lights, not only that, I didn't expect to get a light that would REQUIRE modification just to get it to work normally.
Again that said, I am going to send this light back, with instructions that if their tech support can fix the spring problem, send me the light back. Other than that, I don't want to go through a 3rd copy and the same thing happens again.
To be truthful, it would be hard for me to solder or some way make that spring stay stationary. BTW, even though I am a newbie, I got other lights, and none of this is happening. They work all the time on the bicycles or off. I understand in the course of getting a lot of lights, sometimes I wll get a dude. That's normal, but this is the second one. IMO, a poor design..
cehowardGS
JohnnyMac wrote:
BetweenRides wrote:
+1
+2
Ha, I can't solder, if my life depending on it. Sad
cehowardGS
The feedback you get around here is super AWESOME..
Here is a picture I got from that other thread. The spring is wrapped around the pill. My spring looks much bigger, that is why it hangs loose. My spring tries to grip itself to the walls of the casing. Whereas, this one does it differently, and clings to the pill as shown in the picture!! ???
garrybunk
garrybunk's picture
Can you bend the spring (ie. twist it into a tighter circle) so that it does grip against the pill tighter?  Not a great design, but this fix might make it an acceptable light.
I think you just have to rack this up to the "Lottery" we all play with buying Chinese budget lights, unfortunately.  I am ecstatic if I get a budget light that doesn't need any attention.  I just come to expect they'll need something done (at least thermal compound added).
-Garry
BetweenRides
cehoward, in my opinion, you should not have to be able to solder to use a light (I certainly don't). Many on BLF do enjoy the fixemup lights, but I for one do not. You've tried this one twice, and I think we all agree it's poor design - spring should either be soldered or grip the pill very tight. I say see if they will credit towards another light, as this one is probably not going to work for your purposes.
TadpolePilot
TadpolePilot's picture
Last seen: 3 years 9 months ago
:bigsmile:
One could use a vice or a pair of vice-grigs and smiply tighten one end of the spring so as to have it hold tight on the pill.
"Yell  {"Old, Broken Butt,  Zeide"}&nbs
cehowardGS
Thanks to Kramer for posting this:
Which allowed me to see the spring around the pill.
And tadpolPilot for suggesting to tight the spring around the pill.
Okay, me and my all thumbs, went took the light apart, the bottom of the spring, I squeezed it until it was a tight fit on the pill. Didn't do this before, the spring was hanging loose all the time.
Anway, with the spring tight around the pill, I put it all back together. The light came on, and then I held it in my hand and shook it hard! No mode changes. With the light in my hand, I bang it on my leg about 10 times. (hurt too), as to simulate rough riding on the bike, NO MODE CHANGES. Going to put it on bike tonight, and ride  over the roughest ground I can find, if no mode changes, and no more on one day, and off the next, this light is a KEEPER..
Here are pics of the SUGGESTED FIX!!
Here I am picking up the pill by the spring and the pill is staying attached to the spring, this was never like this before..
As in this picture, the spring is not moving around,
Right now, you all should see the smile on this 72 year old kid!!  Can't wait until nighttime to try this out. I am almost sure this is going to work.
One more thing, not trying to plug Tmart, but they have been SUPPORTIVE from day one on this. No return shipping, and at every instance, I get an apology, and and offer for a refund, with a return label. IMO, if the other companies were just 1/10 as good with their customer service, it would be super good in Flashlight World.
I am going to say BIG THANKS TO ALL, you guys/gals are GREAT/SUPER/AWESOME!!
cehowardGS
-Garry
That is exactly what I did. It looks like that was the fix too. (thanks to all on this forum) Going to ride tonight over bumpy ground, and I should not have no more mode changes or not working stints.. Wink
JohnnyMac
JohnnyMac's picture
That has been my experience with Tmart also and why I was eager to work with them on a group buy for the SR King.  Unfortunately they have been slow to react to my suggestions on what needs to be done to make anything happen with the King.  I haven't heard from them in a few days after trying to contact them about it. It's a shame but I will continue to buy from them when the price is right and often it is.  It's worth the fast US shipping and great service.
kramer5150
Nice to know it works... Everyone likes a happy ending.
cehowardGS
Johnny, in all my dealings with Tmart, their regular reps are great, but I always cc the same message to Sherry Ye, who is on this board. She comes and backs up the already good customer service.
If you get the time, email Sherry your concerns, and see if that helps. In the meantime, I am happy as a lark over this light. Can't wait to go outside.. Cool
cehowardGS
After two test rides on the bicycle, and the ride this morning, once in a while it will change modes on a bump. That is a long way from not working at all, and when working it would change modes on almost every bump. Now, if I can find out where it is contacting to change modes, I might be able to fix that.. I hope. But, I am keeping the light. The way it lighted up the way for me this morning in the dark, I want this.. Wink
Richie086
Richie086's picture
Glad you were able to make the fix without having to solder.
Richie
cehowardGS
If I had to solder, I would have been dead in the water.. WinkWhere is the  gizmo that makes it change modes? In the tailcap?
kramer5150
No its on the driver board, typically an Atmel (or similar) SMT EPROM chip.
Often times its the battery bouncing-shifting around that momentarily disrupts power.  The EPROM senses this power interrupt as a mode change flip.
NightCrawl
Last seen: 5 years 1 month ago
You could still solder it do direct driver.. oh, solder. :/
Or make solder some brass into the hollow part.. oh, solder. :/
You see, I'm making fun of you. Smile
But srsly, I'd try to make the body transfer electricity without need of a spring, I guess on that light, you'd have to remove anodization somewhere
cehowardGS
Funny thing too, I used to be super expert at casting bullets (hot lead), but can't do jack with a little hot tin!! Cry
However, I am moving foward on this. Now, I know what it making the light chang modes, will try to see if I can make the battery chamber a little tighter to stop the movement..
BetweenRides
ce, wrap the battery with masking tape. Start with one wrap around on each end to start, add on as needed. Should work like a charm.
cehowardGS
Thanks ride, going to try that tonight..
Bigpal
I'm a new member, hello all.
I have this light and was having the same issue. The battery adapter moved freely about an inch inside the light. So when I pointed the head up, the adapter would slide back.
When I pointed the head down, the adapter would slide forward and tap the spring on the head. This would cause a momentary disconnect and switch modes.
I put some gauze tape around the adapter and kept it tight. Worked perfect. If your not using the adapter, I think BetweenRides has the right idea by tightening the battery and that hopefully will resolve your issue.
Once I did this, it's really not too bad of a light. Good luck.
