I recently received my DX JM05 clone. LINK My first impressions are fairly favourable. Compared to the last light I acquired, which was the Keygos M10 it falls a little short. Quality wise in terms of anodising and machining it's a little rougher than my other 26650 lights(Keygos, Shadow, Fandyfire), but still acceptable. I like the design and it feels great in the hand, but most importantly it's as bright as the others. The beam profile is very similar to the M10, which uses a similar reflector. The head appears to be bigger due to the aluminum being thicker(a good thing).
When I received the light I had to take it all apart to make sure everything was where it was supposed to be. The spacer around the led fell off when I disassembled it, but it easily went back on. I had to readjust the rubber tailcap as it wasn't put in place properly. There's a brass ring which goes around the underside of the driver and this barely stays in place. It has double o-rings on the tube which tend to stretch when screwing and unscrewing, so you have to mind those so they stay in their proper place. The led itself appears to have a burn mark on it, but this doesn't show up against a white wall. The reflector and lens were a bit dirty and scratched. This can all be chalked up to poor quality control, which is reflected in the low price. When this light is tweaked and cleaned up it is another worthy addition to my ever growing 26650 light collection.
Here's a couple photos to whet your appetite
(\__/)
(")_(")Experience is that marvelous thing that enables you to recognize a mistake when you make it ag
Here's a couple of quick vids showing the light and some beamshots.
(\__/)
Nice review Biggie. Will the tailcap screw fully on using protected batteries?
djozz quotes, "it came with chinese lettering that is chinese to me".
Thanks for letting us have a look at it.
Are the advertized lumes accurate ?
~ Zeroed4x
Not sure about protected batteries, as I only have unprotected KingKongs. Judging by the amount of play with the spring in there I'd say they're a safe bet. As far as the advertised 1000 lumens I'd say it's realistically more like 700-800? This is comparable to the other 26650 lights out there.
(\__/)
Piers said " ....but who wants enough light, when you have the option for far too much "
Thanks for the review, biggie. Nice looking light!
Thanks for the review biggie!
This flashlight looks nice, I though it wasn't a budget light and I couldn't believe the price.
Could you post tailcap current?
Sorry my multimeter isn`t working, so I can`t take any readings.
(\__/)
Hi biggie, I fully agree with everything you reviewed about this light. I ordered mine right after you ordered yours. Mine came yesterday. Everything you reported about the light even down to when you unscrew the front part, the spacer around the led came off, same here. It went back on.
Also, I fully agree that the minor faults with this light is overshadowed by the fact, it only cost us $25.10 shipped.
I only have two protected Keygos 26650 batteries, and they fit perfectly in there. I will say it is tight in that tube, for the simple reason the spacers that came with my other 26650 lights will not fit in this light. It came with it OWN spacer to put a 18650 in. IMO, that is a good part. Don't want anything slipping around.
Going up against the M10 is a tough ticket. But, they are only $2 apart in price so they cool.
To cut the rambling, after one day, on only about 5 or 6 click ons, I am so far real happy with this light. It is indeed a handsome light.
It looks like the addiction had take ahold of me big time!! (big wide grin)..
mine with my M10
Edit.. To let you know how close it is in the battery tube, I had put tape on both my Keygos 26650 batteries to make them no slip for my my BeamTech 4000 light. To put a Keygos 26650 battery in this light, I had to take off all the tape! When the tape was off the battery, the protected Keygos fit in this light, like it was custom made..
70+, Old, Dirty and Fast..
Thanks for the peek, Biggie! That is a seriously good looking light. Far sexier than the M10 IMO. 8)
Thanks biggie!
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
That light is identical to the Shadow JM05 right down to the tail cap and brass rings on the ends of the battery tubes. Biggie, how long did it take you to get it from DX?
I ordered mine a day after the OP order his. When I saw his "just ordered" I did the same. I ordered mine on 3/26/12, it arrived on 4/2/12. About 2 weeks ago DX sent email told me it was backordered and offered a refund. I declined and told them I would wait..
Get one!! IMO, at this price, it is a Budgeteer's dream!!
The M10, Ke-5 and JM05 Clone. However, right before I took the beam shots, I moved the Ke-5 to the right and put the JM05 Clone in the middle and left the M10 on the left.
Here is the JM05 clone in the middle with the Keygos Ke-5 on the right and the Keygos M10 on the left..
I just mounted the JMO5 clone on my bicycle helmet... Oh boy..It has a super spill along with a good throw, all good for my bicycle..
After speaking with my local dealer (Vietnam) this light comes with a 2.2A stock driver.
He’s agreed to swap mine out for a 2.8A driver, so naturally I’ve just gone an pulled the trigger, again :Sp
My initial reaction: wow! what a nice looking light.
Agree with other comments that it feels a little rough and jagged around the edges, but still good enough especially at this price.
I would add though that it more than makes up for it in good looks, in fact it’s probably the nicest looking like I have and it looks better than my JM07 Pro.
I really like the beam profile. Driven at 2.8A the spill is almost as wide but brighter than my JM07. The hotspot is very tight, much tighter and brighter than my XML Ultrafire C8, indicating good throw. And it has a very large bright yellow corona, which makes it a good flooder as well as a good thrower, and a very good bike light. Here are some more pics, it’s too handsome not to post any:
Looks awesome on the MTB. Trustfire A8 (right)
Amongst my ametuer collection. Mine doesn’t have WOLF or whatever it is written on the tailcap.
Juicy review!
Thank you for the review Biggie. And all the nice pics.
Same goes out to whokilledJR. TY 4 the pics
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
I do not think that the BLF-community ben
Ultrafire branded if you are interested.
http://www.ahappydeal.com/product-91042.html
3 days left, but you can pay it later if you put it in the shopping cart.
@whokilledJR
The color is great. Is there a brand or a name printed on it? Maybe some other shops sell the grey version under a different name.
Light up the darkness.
Hi Buwuve, my clone is completely unbranded.
I’m sure it’s the same colour as Biggie’s, perhaps different lighting?
LInk:
http://dx.com/p/new-260-cree-xm-l-t6-5-mode-1000lm-white-led-flashlight-...
Here’s another link:
http://www.ebay.com/itm/160692798941?ssPageName=STRK:MEWNX:IT&_trksid=p3...
I’ve liberally just ordered another light off this seller, so far I’m very impressed, they emailed me personally to confirm it has shipped and emailed me initially to warn me they had been advised the Olympics may affect deliveries into London (i live 500 miles away but its the thought that counts). On this alone I’m feeling good about the order, if it comes in a reasonable time I’d have no problems pointing other people too them.
I also like that the lights I have looked at seem to have at least plausible lumen ratings.
http://theflashlightforum.com/index.php
http://www.thevapingforum.com/index.php
Which is the best for you?
The M10 is a winner because of price. The JM05 Clone is good too for the simple fact it is a little shorter and I use all my lights on my bicycles. I had to send of these back, because the washer kept falling off, and the light wouldn’t come on or change modes. The M10 at $19 to $22 is a tough one to beat.. I got 3 of the M10s, and two of the JM05 clones.
Thank you for the links
Your flashlight has a gungrey color, biggie’s and my own (I have the long 2× 18650/26650 version) looks more bronze colored. Maybe the different cameras and lights make them look different. I like the flashlight and think about to buy the short version.
