This was a fun build.
I had 4 XML’s pulled from a couple of Chinese lights that I had done emitter swaps, along with a red Mag shorty host, and custom aluminum heat sink. About an hour or so later I had created a monster parallel wired, direct drive 4 x XML torch.
Prior to connecting the stock Mag switch, I tested current and measured nearly 8 amps using a freshly charged IMR 26650 battery (gold color, not sure brand but possible King Kong). Testing current draw with the switch in line (prior to soldering) I measured about six amps. After soldering and assembly, I tested the tailcap reading and again measured about 6 amps. However, ceiling bounce test told a different story. Without the DMM hooked up, I measured 149 lux, but with the DMM at the tailcap, I only measured 92 lux. Clearly the DMM was adding resistance, so I am definitely getting more amps than my DMM is telling me.
DMM at tailcap | Amps | Lux |
No | ? | 149 |
Yes | 6.1 | 92 |
Pics of build
XML's were mounted on the heat sink using thermal paste, aligned with the 4 x optic, then glued down on the edges using arctic adhesive. Wiring was done in parallel using AWG 24 copper stranded wire.
The heat sink was constructed from two different pieces of aluminum bar stock, cut and glued together. Copper tape was used to create a snug fit within the mag head and body tube for heat transfer.
Switch wired up as direct drive
Line up of lights used for beam shots and ceiling bounce. Most of these have been modded to some degree. (Check table below for specifics)
(L to R) Sky Ray 1JC8, Trustfire 3T6, Sky Ray STL-V2, Ultrafire 7 x XML, MVP, Mag shorty (this build)
Ceiling bounce test.
All lights are on max with freshly charged batteries. Readings taken immediately after turning on.
Torch | Mod | Lux |
Sky Ray 1JC8 | 5000K XML; 8 x AMC 7335 driver | 40 |
Trustfire 3T6 | 3 x 5000K XML; stock driver | 59 |
Sky Ray STL-V2 | 40000K XML; stock driver | 43 |
Ultrafire 7 x XML | stock | 119 |
MVP | 3 x 5000K XML; 8 x AMC7135 driver | 110 |
Mag shorty | 4 x 6000K XML; direct drive | 149 |
Outdoor beamshots
Note: I only have a point and shoot camera with no manual exposure so these photos are not the best since my camera automatically adjust for exposure, but at least you get some idea of output. Order is same as pictured above.
