Ordered the light from WB. Even paid local taxes and everything.. Lets take a look and see. But first..
Why this light? I considered the BTU, TR-J19, Marsfire 318, but I liked this the best. Looks, form factor, size, weight... Most seemed right. I had a feeling it came with a decent driver as well after seeing Relic38 put 3 MT-G2s in his and using the stock driver, just modified a little... Not sure if my driver is the same though. Either way, I requested the light to WB and they got it in for the best price I have ever seen.
This is more like a simple first impression overview, not a proper review. Lets see what I got..
Came in a big box..
Read this user manual. You are in for a laugh.. Thanks Lustefire... :D hahaha...
Its big. Almost the size of a 9 XM-L Fandyfire ..
Large head.. Me likey... :)
Some useless silicone stuff on the driver circuit, it was easy to scrape off.. No spring...
The center goes a little bit into the battery tube...
.. which means if use 3 long protected 26650 (Soshine) and tighten it too much. The battery hits the aluminium and turn the light on (the button is rendered useless)...
Solution, do not tighten properly if you use long cells.
Threads were nicely lubed..
With short unprotected 26650 (Sony rated for 50A drain). The light will not even light up, because the batteries are not long enough..
Solution: Use a little spacer or add spring to driver circuit...
Emitters are wired in parallel.
In the center, where the screw that holds the reflector the aluminium is only 2,1mm thick. But around the edge, where the wires come up, its thick..
Centering device on all emitters, works as insulators too. Looks like 20mm MCPCB can fit without any work.. Stock MCPCBs looks to be 1 mm thick and nicely secured with thermal silicone or something..
Head is a 2 piece design.. (front part is not shown in this picture)
32mm wide driver circuit with good mode memory. Can probably be resistor modded...
Reflector vs C8 reflector:
Good room for wires. Makes it easy to get de-domed emitters focused..
Crappy spring on the driver, it was almost completely stiff...
The big Omten switch.... :) Based on my own and others experience, these seems to handle 10-15 amps easily. Im not sure where the limit is. But its a good switch and can easily be replaced..
Some measurements done by me:
Lens: 80,9x3mm
Reflector: 79x38,1mm
Driver compartment: 32x 19,8
Emitter amps on high: 7,36-7,8 depending on batteries and how long I wait.. (7,8/3= up towards 2,6A to each emtiter)
Tailcap readings: 2,6A - 1,37 - 0,33 - Strobe - SOS (these may not be 100% accurate, but tailcap current should equal emitter current)
To sum up my first impression
Well built, well driven. Good value. My largest complain would be the lack of driver circuit spring, but Id guess they did that in order to easier fit longer cells. That was a semi-success, because my longest batteries did not fit properly, and short unproteced cells was not something that worked.. Not uncommon issues really...
All in all, a recommended light, even as it is stock. :)
Great mod host too!
