These are protected 32650 li-ions.This cell format is very rare and only few "manufacturers" offer this format,most known is feilong. Recent tests on net showed poor quality,that basically means no decent quality 32650 exists on market.The last alternative is trustfire,but should we trust trustfire?
So here's the first test:
2 tested cells show more capacity than expected(around 5650mAh at 3A and over 5700mAh at 5A),high voltage,and good tracking(ignore small difference at 5 Amperes,I was little impatient so 2nd cell wasn't fully charged,it was at 4.17V,while 1st one was at 4.19V,hence the difference).
Test at 10 Amperes activated protection circuit,that was disappointing.
So I removed plastic wrap to see pcb:
Only two 8205 mosfets,just like on 18650 cells?!
Next I tested bare cells with protection removed(5A and 10A only):
Result at 10 Amps is 5797mAh and voltage during discharge is much higher than on protected cell.
Temperature rise at 5Amp is about 7C,at 10Amp about 20C(that's much better than feilong(good one)).
Here's graph showing protected vs. unprotected cell at 5Amp:
Internal resistance can be calculated from these graphs:
Protected cell:~50mOhm
Bare cell: ~17mOhm
Protection circuit:~33mOhm
Based on all these data this cell (bare) should withstand 15 Amps without problems.
Comment:
Based on tests,this looks like best 32650 cell available on market.Capacity is excellent,especially at high currents,and internal resistance is low.But putting 2 mosfets protection on this huge cell is just ridiculous.
