Just got my 3x 7135-based SRK boards in today. They’re very nice. Not only do the purple and gold boards look great, they feel like they’re well made. I have my parts on order (though I may be waiting a little while for my 7135 chips from FastTech)
Overall, very pleased w/ OshPark (and shout outs to the board designers too).
I’ll post the links in the op if I have wifi in the next few days. Do you have parts lists for these and are you going to provide firmware or sell flashed mcu’s?
That’s a pretty amazing bit of programming in that video.
I’ll put together a parts list today or tomorrow and post it. It looks like most of you are set up to program Atmel parts, so it’s probably easier for me to provide programmed PICs, but if anybody wants to build one and has a PIC programmer I can provide the source
Welcome to the forum tterev3. You come here with substantial and unique knowledge acquired outside this forum. That is great because much of what has been accomplished here has been built "in-house". Thanks to hard work of former and current BLF'ers. I'm not one of them. I'm just a follower.
I have a humble request and totally understand if you don't have the time or interest to oblige. It would be awesome if you could create a thread giving a high level how to on PIC programming. Doesn't need to be step by step. Just equipment and software needed. I've attempted to research it a couple times, but have not been successful in finding much info on the subject.
No it's not. I designed it as a simple back up for something else I was making but I don't have any intention to actually use it. Figured I'd share it for anyone who wants it. Basically a 2 cell driver set up so you don't have to stack parts. 20mm in size so a bit limiting.
I'm no expert (hell I can't be bothered even compiling my own code half the time!) but I experimented with PIC programming when I bought a few of PilotPTKs 3xXML modules last year. From my experience, PIC programming (when taking into account the cost of equipment, ease of use of software, and component choices available) is a hell of a lot more troublesome and expensive than the ATMEL programming we generally do around these parts. I'm not sure what the advantages of PIC is over AVR, but I'll take AVR anyday. Again, that's just based on my LIMITED experience!
tterev3....Welcome! I actually emailed you through your site, never got a response but now I see that blogspot never actually informed me that you did respond. Email incoming :)
Don't let me put you off it. A thread like you suggested might be helpful. If it's written by someone who knows their stuff it could show how little I really do know ;)
That being said I had to pay $40+ for my PIC programmer whereas my AVR programmer was about $2. The AVR programmer also clips straight onto the IC, where as the PIC needed break out pads and a home made adapter. Depends on what PIC package you choose of course. The PIC software was also not that great but I really can't compare it to AVR studio as I've barely used that either.
Run 3x layers of clear finger nail polish over em…that’s what I do when I want to weatherproof conformal coat PCB’s…that or run some clear RTV silicon over it and let it self level…but the bubbles…uggh
I just realised I never provided a Version 2.0 FET SRK driver. Did people still want it? It's done, it just hasn't been uploaded. It includes a few minor layout changes as the addition of the resistors on the FET gate.
Before last night’s little coat pocket liner burn through, I had ordered an UCLp lens for the M6. It came today. I put it in and it looks awesome on there, anybody think the M6 will melt it?
That may be the reason why I never bothered releasing it...no need for it. I might still do it, but then again it may confuse people. I should pull some of the earlier revisions of the various boards I have on OSHPark. Anyone care to give me an overview of what should stay and what needs to go?
I have the 15, 17, & 20, but haven't experimented with those yet. I still need to see how they act with/without the resistors. I never got any of the intermediate 17DD, after the ground pads on the back were added, so the ones I was playing with that didn't work without resistors were the very first ones. I also have a few different FETs to try, to see if those will eliminate the need for the resistors, if the new boards don't work without them too.
Screw it. I was holding onto this to build and sell but shipping from Australia to anywhere in the world makes the driver more expensive than is reasonable.
Not for the faint of heart. (though not as insane as tterev3's board...which I look forward to building!)
4A buck regulated LED driver. The driver half (top side) is tested and works. What is not tested is the MCU side (bottom half with MCU and voltage regulator). The whole driver should work as all the MCU is doing is feeding the driver IC a PWM signal. That's it.
Please note I have specified 10K and 3K resistors for the voltage divider circuit however you could easily use the resistors that come with NANJG drivers and use any of the dozens of available firmwares. The only "not sure part" is what PWM frequency will give you the best results with the driver IC.
The design is tight because I intentionally chose leaded parts so that it was easy to solder. Built with the DIYer in mind ;)
If anyone does go down the path of building this, please let me know how it goes! I'm ordering the PCBs and parts myself very soon.
- Digikey do not stock Coilcraft products. Coilcraft do however give out free samples. I got 10 of the required inductors for free :)
- R2 and R3 are my choice of resistance value for the voltage sense circuit. Either adjust the firmware to take these values into account, or use the resistors that come with NANJG drivers. Also the cart includes 10 of each of R2 and R3.
- You obviously do not need to buy U2 if you are simply swapping the MCU over from an NANJG driver.
Will do, but I want to relax for a bit. I've spent the last 3 hours looking at PCBs. I'm gonna play some Titanfall I think! Should have a cart up later tonight or early tomorrow morning :)
