Picked up my 7078MUX-GHP from the post office.
There’s different packaging and a leaflet inside, an interesting bit of info on the leaflet and repeated on the box.-
So I would guess that they’ve decided to enforce this law more stringently.
If the result is that we get knives like the 7078 then that’s all good! Very nice non locking flipper that doesn’t flip at first but loosening the easily turned T6 pivot and Loctite applied cured that. It did move the blade over a bit but still not touching the liners and I know how to cure it, the detente arm on one of the liners must be pressing more than the other. A strip and rebuild at some time but it’s not urgent.
I have noticed that the Torx screws through the back spacer are screwing into blind fasteners so just three, including the pivot, T6 Torx screws to take the knife apart. It’s going to be difficult to unscrew them if they start turning in the back-spacer/scale.
It feels good in the hand, the shape of the scales fits my hand with a three fingered grip, the little finger grabs a simple lanyard threaded through the last hole on the scales. I cant help thinking that they missed a trick by not drilling the pocket clip in a similar pattern.
The flipper will work but mine took a bit of pivot adjustment and lubricating to work properly and even then requires a wrist flick to open. This will all smooth out as the knife wears in. The thumb studs are O.K. but an easier and less aggressive way of opening is to press your first finger on the flipper while pushing out slowly with your thumb on the thumb stud, sounds silly but it works and overcomes the strong detente. The knife is tip down carry, the pocket clip isn’t moveable but if you remove it and use a lanyard then it’s truly ambidextrous with a thumb stud on each side of the blade and scales scalloped the same on both sides plus the flipper of course.
The blade steel is not marked but it is Sandvik 12C27 as used in the more expensive Real Steel range. The blade is as sharp as all knives should be from the factory - very sharp.
The characters on the blade read Three Blade Wood or San Ren Mu.
If this is the style and quality of knife that SanRenMu are going to be producing in future I’ll willingly buy them, I’m already thinking of buying the “Toasted Almond” colour and there’s a red or orange one out there somewhere as well.
For the price FastTech for, $11.60, or about £7 they are a bargain.
I know a lot of knife owners don’t like slip joint type of knives but this SanRenMu system is very good, in the U.K. we are limited in what we can carry and with this - non-locking but strong detente - and the 68mm blade this is EDC legal.
Here’s a picture from the ’net of the inner workings of a SanRenMu 9054, same system.
Simple and quite secure. A step up from the slip joint with a back spring but still non-locking.
I would urge those who won’t buy non locking knives to at least try one with this system, the SanRenMu 9054 shown above, this one’s bigger brother with an 83mm blade would be a good choice at only a couple of $ more.
