Summary: The driver for the BLF Manker A6 has issues with extra flashes when switching from turbo to moon. I determined that this is due to the MOSFET selection. I am looking for a partner to fund and test drivers with 5 different MOSFET parts.
I built many of Wight’s DD+7135 driver and never encountered the turbo-to-moon flash issue. Comparing that with my home-assembled driver, I used a different MOSFET: PSMN6R5-25YLC instead of the PSMN3R0-30YL used in the Manker driver. I swapped the MOSFET in the Manker driver and the flicker disappeared.
Doing some research, I suspect the flicker issue is due to Cdv/dt induced turn-on.
When the FET is on in turbo mode, it causes the battery voltage to drop. When the FET is turned off in moon mode, the battery voltage recovers. This causes the change in drain-to-source voltage that triggers Cdv/dt turn-on. The white paper mentions that if the gate driver can only pull the gate down to 0.7V, then the Cdv/dt induced voltage is added to this 0.7V to make turn-on even more likely. I checked the ATtiny13A data sheet and the output low voltage is only guaranteed to 0.7V.
What makes matters worse is that the Vgs or gate turn-on voltage decreases when the junction temperature increases. So the longer the light is on turbo, the more likely that it will flash when switched to moon.
The PSMN6R5-25YLC that I use has higher on resistance and so the turbo current will be lower. But will it still be acceptable? However, I don’t have the equipment (top batteries, thick probe wires, lumens meter) to do accurate measurements.
I am proposing to purchase five different MOSFETs and build two sets of five DD+7135 drivers for testing.
Here is the parts list from Mouser. With the circuit board from OSH Park, the total BOM cost is about $36 shipping included.
I am looking for a partner with the proper equipment to help fund this project and conduct tests. I will hand assemble the boards and keep one set of 5. The partner would chip in $20 to cover the parts and shipping of the other set of 5 driver boards and is expected to perform tests and post the results here.
Priority will be given to a member that already have 4 or more of Wight’s DD+7135 boards ready to ship to me. I already ordered 12 boards from OSH Park, but it will take them time to make.
