UltraTac K18 Brass - Mods & Lighted Switch
Nichia 219C D320 5000K on Cu DTP MCPCB
Flat top cell compatible
Potted driver
Lighted low profile GITD switch 0.7ma drain
Tailstands
Magnetic tail
Lockout-able
Graphite aesthetics
Chemical patina
Max – 340lm
cd – 1140
Throw – 68m
Out the box
Cut off keyring attachment and applied graphite/ resin mix
Swapped emitter to Nichia 219c, upgraded wires, installed LED under switch and filed out retaining ring
Lighted switch operation
Thanks to member Saypat for gifting me this light. :+1:
Very nice Crx! Way better than the stock now :wink:
Thanks :slight_smile:
Saw this one in the wdymd thread as well today, very nice mod!
Sweet. Very nice. Its unrecognizable from the original light. Thanks for making its own thread as well. :slight_smile:
Thanks guys :+1:
Very nice one!
For me the tailstand is also very important. How did you cut the tail?
Very nice mod! Regarding the non-fitting positive driver contact: I had the same problem with mine, Efest 10440 just didn't make contact because of the driver retaining ring. I just put a blob of solder on the positive driver contact and then it worked.
Where did you get the neodymium magnets from?
Thanks. A junior hacksaw and file will do it no problem.
Thanks. I would usually solder a thin copper circle to the driver contact but i made the copper button disc as a temporary measure until i work up the courage to go for getting that retaining ring out, then i will dremmel the offending ledge away so the cell fit through it.
I use spider magnets in the UK
Nice read. Great Pix!
Cheers mate.
OP updated with pill removal & emitter swap.
These work fine in all 4 of my K18s
http://www.rtdvapor.com/efest-imr-10440-350mah-button-top/
But i don’t have any of them :stuck_out_tongue:
Handy to know though, thanks for pointing them out.
and I didn’t want to spoil your fun :wink:
