But bad UI
Regards Xandre
But bad UI
Regards Xandre
If only did it not have blink I would reconsider the Jaxman Z1 host build.
Good find.
I don’t mind the blinky mode but it could use a medium mode and maybe a few more amps the power is still okay…
anyone tried it? can be moded ?
Hey mate i bought one but i am yet to use it. I will try tomorrow if i get time.
nice,hope it worth it.
13w is normal for an xpl or similar. Why go for multichip xhp35 for such low wattage?
Hotspot would be larger? And efficency lower?
Low mode 0.5amp input - 0.17 amps output
High mode 4.22 amps input - 1.13 amps output
Would this driver fit inside of a c8 or x6?
its 22mm driver.
thanks zeremefico,did you tryed to mod the driver? any sense resistors ?
Absolutely not, 17mm vs 22mm
Not visible sense resistors, I will take some macro pics soon.
Not bad should be good for over 1800 lumens
Was just curious would make w great mod I would think. I have a sipik 98 clone and the guy on here that did it used a 20mm to 17mm adapter so didn’t know if there was some way to make it work somehow. Even by shaving the driver down if that was possible
I believe sense resistors are under square component.
will34: Speed4goal:Would this driver fit inside of a c8 or x6?
Hey mate you should be able to make it fit by shaving down the light on a 20mm driver light I was thinking about using a D80.
Yea the driver doesn’t look very mod friendly
thanks for the photos.
Are mods possible to drive the led with at least double the current?
http://schmidt-walter-schaltnetzteile.de/smps_e/aww_smps_e.html
1A LED, I Shottki diod=8.5А
2A LED, I Shottki diod=13.5A
I think the driver will burn
