I prefer that lights like Xeno E03 and Trustfire R5-A3 have a clip that permits wearing on the bill of a baseball cap as a headlamp as well as pocket or belt carry. R5-A3 has a clip but it points the wrong way for a cap.
I ordered clips from Fenix gear, one PD10 which fits the R5-A3 and one LD20 which fits the E03. Both clips have a nominal ID of .9 inch, however the PD10 clip is too tight for the EO3 and fits the R5-A3 perfectly. LD20 fits the EO3 perfectly.
The clips are $1.50 each and shipping for both in one envelope is $1.
I think you mean the clips cost about $35, now I need to get a Xeno...I've only hesitated as it was worthless to me without a clip. Thanks for the tip, I really wanted one!
It's a bit more work and you need to be careful not to scratch the anodizing but the PD-10 clip does fit on the EO3 and it is quite secure once in place.
[quote]
Mine are always put on tip pointing down from the head, I do not waste money on separate headlamps that way....they fit an ordinary cap.
[/quote]
I've done that with other lights. To be honest I'm not sure why I didn't do so with the E03.
[quote]
On the E03 the clip shows the writing at the top of the flashlight betwen the cutout in back and fits 90 degrees off from the finger grooves. Perfect
[/quote]
A bit unrelated but ...one of those two pictured is a replacement for another E03 that was faulty. On the one I returned the finger grooves were 180 degrees from the writing rather than 90. I had completely forgotten about that until you mentioned it.
There is a guy over on CPF with a Xeno with a nitecore titanium EX11 clip permanently attached, and he "heat colored" the clip giving it a cool rainbow-ish look.
I think the permanent clip is the only way to go if you're going to bother.
