Review: Wuben T102 / XHP70 single 26650 Allounder
Wuben T102 - a short review
Hello my friends!
today i made a short video and some pictures of te Wuben T102 - a very interesting flashlight...
lets start with a short video:
the specs:
Features:
·Utilises XHP70 N4 LEDs, max output up to 3200 lumens
·Max runtime up to 1000 hours
·Max throw up to 400 metres
·4 brightness levels and 2 special functions available
.1/4" tripod mountable,best helper for photograshing
.Orange reflector provides a wide and even beam-fits for cave exploring night walking,search and rescue.
.Advanced temperature regulation(ATR)technology
.Digitally regulated output maintains constant brightness
.Reverse polarity protection
.High class customized aluminum packing box,tough and strong enough to protect the product
·Made from aerospace grade aluminium alloy
·Waterproof in accordance with IPX8 (2 metres submersible)
·Tail stand
Package included:
1 x Wuben T102 XHP70 N4 3200LM Tactical LED Flashlight
1 x TYPE-C charging cable
1 x O-ring
1 x 5000mah 26650 battery
1 x Carrying Box
1 x Manual
what i think:
its well made - strongly glued body (the anodizing did withstand somebrute force - but not all)
i like the size and form
a very nice , useful light IF you are okay with the User Interface
on the one hand its nice to have a simple UI, but i wished a bit more possibilities on a light this strong!
USB charging works good
overall a good allounder!
when i am sucessful dis/reassembling the light i add some measurements!
all pictures with some comments:
it comes in a nice Box!
save shipping is granted
The Light and Accessories
one charger for EU and US
charger
mounting EU Plug
mounted EU Plug
Type “C” USB cable included
5000mAh Wuben cell
5000mAh Wuben cell
the color underneath looks familiar
slightly raised top
the Light
nice Fins
the driver section is not round which i like
the switch is raised enough to be found in the dark
i like the switch – alltough i wished the colored leds would also show voltage of the cells or such
Stainles Steel attack style bezel
orange peel textured reflector
the lens is AR coated
the LED is centered well enough
the thread for camera stands
works in upright position
maybe a higher quality one can handle the weight
square threads (lubed a bit) uon the taill cap
inside the tailcap
the double! spring is flattened for better contact
flattened driver spring as well – but no double spring
a look into the battery tube
the charging port cover sits nicely
i would not throw this into water – but i am sure it withstands heavy rain
cable plugged in
underneath the switch vover a red lights indicates charging
when 4.19Volts are reached the LED flashes blue
and it stops charging!
the MCPCB
the OP reflector with a sealing ring
the reflector again
and again
AR coated lens
around 2mm thick with the SS bezel
the quite massive centering ring
removing the switch
removing the switch
the switch PCB with some LEDs
the switch PCB
light enters with charging port open
with the switch removed
a look on the copper MCPCB and LED shelf
mounted again
turbo @ f/2.2 S1/10 ISO 400
high @ f/2.2 S1/10 ISO 400
mid @ f/2.2 S1/10 ISO 400
low @ f/2.2 S1/10 ISO 400
removing the LED – good amount of thermal paste was used
MCPCB
also good quality
small dimple filled with thermal paste
to be continued...
PS: a sub US$ 80 code is available ;)
reserved
That is a nice looking, well built light! Have eyeballed it a few times. Good write up, good pics… well done!
Nice light !
It is good to see you review some nice lights again :slight_smile:
Found this on KD website back in August, wishlisted it and forgotten, now I just see it again and found your short review. I also watched your video. Thanks for the nice review & disassembly, plus the video, they help with my decision as I’ve been looking for a good single 26650 xhp70.
This looks decent, and well built. ($81.81 on KD) Nice case and the included wall charger and battery but I don’t really need them, probably driving the price up a bit more than I’d be willing to pay because of its shortcomings (see below)
What I don’t like:
  • Only 3200LM max
  • Cool White 6500K
  • No quick access to Turbo
  • No Knurling to tube
  • Crenelations on bezel
  • Price a little high
Wuben: Make a NW version/option, add quick access to turbo, boost output to 4500-5000 and offer a lower price option non-kit for flashlight only, and I bet you will have a lot of attention for this among members here.
Still looking.
from my blog ;)
type Brand model = my Link Code price (US$) shop
FL Wuben T102 WT02NP 63,99 gearbest
FL Wuben T102 MT102 78.95 banggood
Showing 1 to 2 of 2 entries (filtered from 865 total entries)
