New BLF GT Narsil M Cheat Sheet for v1.2 NEW VERSION
Hello everyone,
I tried to shoehorn Tom E’s Narsil manual in a table.
It’s called Narsil M Cheat Sheet and you can download the PDF from this Google Drive page.
the short link is:
Feedback is appriciated.
Thanks
Joechina
EDIT:
  • Hello,
    two new cheat sheets vor NarsilM v1.2 are up
  • The Cheat Sheet for NarsilM v1.2 is ready. NarsilM CS v12 Q8 2017-11-23.pdf I also made a Rev. C for NarsilM v1.0
  • NarsilM CS v10 Q8 2017-11-23
    (only Lazy-R-us must update :slight_smile: )
* There is a new cheat sheet for NarsilM v1.0 (for Q8 Rev. B) Narsil M Cheat Sheet 2017-10-25 from
http://bit.ly/narsil-cs
Changes:
- The cheat sheet has now the same values for mode groups as the operation manual that came with the Q8.
- The ? Instead of ° (degree sign) seems to be a glitch on a chinese computer.
- A sentence below the pictures.
- A few words about how to set temperature step down.
There is a new notes section:
- Added examples how to click
  • Link to JasonWW’s videos
  • The version
    Narsil M Cheat Sheet 2017-07-20
    is the version sent to thorfire
* I made a new version
Narsil M Cheat Sheet 2017-07-19
The edits are only on the first page
- with corrected links
  • and added how to switch off the indicator light.
    The sheet is on the same Google folder, but it has now a bit.ly link
    NarsilCheat Sheet (PDF): http://bit.ly/narsil-cs
Reserved 1
Reserved 2
Dude, that is slick! Really want to get my hands on a Q8, sounds like it will happen soon!
Wow very nice Joe!
Let’s ask Thorfire to print this at 95% landscape and put it in the box for it has links to the important BLF posts and threads and a clear overview
Awesome, thanks so much!
Nice, thanks!
Got it working, it took changing the printer setting to A4 (it appeared to be in USletter for some reason) and then front and back aligned almost perfectly. :slight_smile: I will store it in the Q8.
Note to self: always bring your reading glasses when using the Q8 :slight_smile:
@djozz
Whoo, looking good.
I don’t why you had letter format, mine is everything in A4.
I don’t know if it fits, maybe you need verry thin paper.
Cool, I’ve added this to the others
Thickness of the stack that I made is 1.6 mm. I will have a look at home tonight how well it fits, but it feels thin enough :slight_smile:
Thickness of the pack is 1.6mm, the space in the rear of the Q8 proto3 is 2.2 mm. So it fits! :slight_smile: :
Wauw!
That is great!
Also neat that owners can write phone Nr and email on it, ready for a BLF meeting :slight_smile:
Thanks djozz for the video and testing!
I guess that’s a unique feature for a flashlight :slight_smile:
Are there BLFers using the latest Narsil version who can check this?
Would be awesome for it is about time to email Barry the to be printed manuals.
I can’t check any info contained on the cheat sheet, but nicely done on the actual cheat sheet!
Awesome manual now it is time for Q8.
Man i wished it could happen, imagine a BLF gathering but i am living too far away. How many lumens in total if we switch on all the lights we have at the gathering
Probably a lot! I EDC probably 4k lumens. But for special occasions I bring bigger lights.
Whew. This could be a new competitive maze-type game.
Starting off at one setting — find the minimum number of clicks to end up at a different setting.
Hello,
I need proofreaders.
I hope the new notes help to start with NarsilM.
I edited the OP:
Changes:
I feel like the dumbest guy alive. I can’t figure out how to program from ramp to modes. I’ve read the directions 20x and I know I’m missing something simple
Hold down the switch for about 8 seconds until the light flashes. When it does click the button one time and it will disable ramping or two times to enable it. After you do this hold down the button til the light shuts off. Don’t worry about what the light is doing(flashing or whatever) just keep to this direction and it should change for you.
