Sofirn AAA 900mAh (Black-Blue)
Official specifications:
Capacity: 900mAh
Voltage: 1.2V
Chemistry: Ni-MH
Rechargeable: Yes
PCB Protected Board: No
Maximum temperature raise at different discharge currents: 1A:+2,2°C, 2A:+5,4°C, 3A:+8,4°C, 5A:+12,3°C
In my test Sofirn AAA batteries this is the lowest capacity cells (The other are 1100mAh and 1800mAh), can this battery live up to its specifications?
The discharge curves looks fine with a very good match between the cells and capacity is close to 900mAh.
Conclusion
These cells has about the same capacity as the 1100mAh & 1800mAh and that is about 900mAh.
The discharge curves looks fine.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
