Thank you for explaining this…but…why it has to check if a device is connected?
In this mode it drain battery more fast but I switch off the led button…I don’t like color
Maybe not only the powerbank controller. Anduril wakes up several times a second to check the battery voltage. That will increase the power consumption as well. I’ll take a measurement (of a different anduril flashlight) later.
FWIW, the wide regions of increased current are fixed now. I didn’t have it properly going into the ADC sleep mode during measurements, so it stayed on way longer than it should while checking the battery.
Overall, the fix seems to reduce average standby current by about 15 or 20 uA. With aux LEDs on low, that means a drop from about 100 uA to 80 or 85 uA.
Wurkkos has semi-recently redesigned the drriver for the TS21 to use a T1616 MCU instead of the old T85. I’m guessing they probably also fixed that issue with the new driverr.
Can’t speak for detailed revision codes but if you take the tube off and look at the driver, the new version will have 3 flashing pads visible.
I bought one a few weeks ago. Draws 3ma on high. That works out to 70 days. And draw will go down as cell depletes so probably 50% longer than that. I just leave aux on high. I find low too dim
