agree… I think there will be some fine tuning to bring the aux and button function in line with more standard Anduril 2 RGB controls.
I just removed the bezel and confirmed the LEDs are 5000K 519a. The color rendering is top notch, particularly in regard to Red, far superior to LH351D
I would not call this a Very Floody beam, it is more like a Carclo Narrow Clear, that throws a more concentrated beam of light. Not what a carclo wide frosted beam would do, which is what I mean by very floody… try looking at the beam profile in the first photo to get a sense of what I mean.
As far as water resistance, I would not volunteer to drop any light into hydraulic fluid… this one does have O ring seals, but they are not double, like in actual dive lights. I have not looked at how the button is installed, I do not know how it might be sealed. Bezel does have an O ring that presses on the optic, plus another O ring at the bottom of the bezel threads…
Regarding pocket clip, there is a groove for one, hopefully a suitable clip can be sourced. I do think a clip is a very important option, to clip to a belt. Else a Holster for that purpose.
5000K 519a :+1: It is the LED I asked for, and I confirmed it is what I received.
You cant tell from the photo, but with my eyes I could see the little corner marking that I look for to ID 519a. I compared them to an LH351d I had just removed from an SC21, which has an obviously larger dome, that extends almost to the outer edges of the die. The domes on the 519a are a little smaller.
I suggest you contact Wurkkos to offer your help with the Aux and Button light coding
I do not know if the Aux lights have LVP, do you know? I think yes because iirc the RGB Aux should have LVP. Can you confirm? The present Aux configuration is not yet using standard Anduril coding, but I was told that is the intention for the next revision.
