This flashlight was built for weapon mount, long range use. It features solid copper heat sink, Ebay seller DTR-LPF PT54 red led, Optolife 50mm Aspheric lens, Direct Drive 4/3AF (18650 size) NiMH batteries, 18GA Teflon wire and a MF $13 TR-1200 HOST W/Ebay extension. Wire tape switch (too much resistance) will have to be reworked probably MOSFET switched. Using standard switch or copper penny :) . Running 3 cells was able to pull 12A. A bit high but this a short run time light. All copper parts turned and host bored for press fit. Not finished but work in progress.
Pill with threads and angle wire hole
Back side of pill with insulator installed.
Pill showing contact and 18GA Teflon wire
Pill with emitter installed with torx screws and soldered wire
Side view with rings installed.
Bell bored for lens
Bell with lens ... note keeper/spacer not finished at the moment
Bezel installed showing lens below front and recessed. Note missing keeper/spacer.
a work in progress........
