I decided to make a Trio of Maglites. The Blues Brothers. I already had a 2D Blue and found a 2 pack 2AA & 2AAA Mini Mags, in Home Depot, so I brought them home to meet their big (now small), brother.
I had already been working on the 2D, to make it into a 1x26650/3AA host, but now I will complete the trio and sell them together.
I intend on putting XM-L emitters in both the 2AA and 2AAA lights, with 2 Alkaline batteries. It should light them up direct, although not as brightly as with 3 batteries. I do have a board for the AA light (14mm board), but it's only like 700ma. 3v off 2 alkalines should put out about the same?, according to Cree specs. There is no board small enough for an AAA Maglite.
Anyhow, I will be dressing them up to match each other. It will be interesting to see if I can, on the small lights.
The AAA Sub-thread is HERE...
The AA Sub-thread is HERE...
More to come, later..............................................................
I tried doing some filework (vine pattern) on the bezel. It did not work Jack! What a mess. Anyhow I thought about tossing it, but then I just tried to make it look like something. I don't like it, but I'm not going to try to find another Blue Maglite and start all over again. The heck with it, it is what it is.
I also made a heatsink. I don't have much room for a heatsink due to the deep reflector and shortness of the light. The only thing I did different is to make a spot for the driver, where I can solder it right to the copper outer sleeve of the heatsink and hopefully my poor ground problems will be resolved.
Later..........................
The cosmetics are almost done:
Being as this is a "Set", I needed to have some continuity with all 3 lights. Due to the small size of the AA/AAA and other factors, I chose to do it this way. The AA light does not have any body rings cut yet. I still have to finish it, but I wanted to give y'all a taste.
Carry on...
Tailcap Switch,
I have done one of these before, but I figure I should show this one, so newer people can get the idea. This is a home made tail switch assembly.
Here's the components. The tailcap, A Judco switch (10amp pushbutton), A plastic bushing from lowes, a piece of 1" copper coupling and 24 gauge flat copper, a gold plated spring, a dd circuit board and some 1" plastic washers from Lowes (not shown till later).
Lowes has a bunch of specialty fastners in metal bins. I get most of my plastic bushings, washers, screws and nuts from there, as well as the copper pipe & fittings.
I start out with a small drill, like 1/8" and drill the center of the tailcap. Then I go up to 1/2" and from there I use the rotary bit. As you can see, it's not perfect. To get it perfect, one needs "the L word".
With this switch assembly, I decided to make a step, so that when the bushing goes into the tailcap, the step makes a stopper. This was done with a rotary tool. Again, it's rough and not a perfect fit. Thank goodness for Arctic Alumina to fill gaps and paint to cover it up.
Here's the bushing and switch set in place in the tailcap. I used a tapered stone in the rotary tool, to give the taper to the center hole, so it's easier to access the switch button. The button is less than flush, so tail standing can still be done.
Inside with the back part of the switch.
The 1" copper coupling is too big to fit down in the tailcap, so it has to be split and about 1/4" removed, so it can be squeezed into the tailcap. The cutout is to clear the contacts of the switch, when they are wired. The top piece of flat stock, is to keep the switch from backing out. This copper bushing is press fit and keeps the assembly from moving back, as well as being a ground for one of the wires of the switch.
A shot of the copper bushing going in. I will not drive it in for real until it's ready to go. I don't want to try to get it all out again, as driving it out will probably mess up the switch.
This shot gives you an idea of how the assembly sits in place. The slot lets the contacts and wires be clear of the copper. One of the wires will be soldered to the copper.
The last shots show how the spring assembly will go together. The 1" washers sit in the top lip of the tailcap. I use the blank board sandwiched in between the washers. The other switch wire is soldered on the bottom of this DD board and the gold spring is soldered to the top. AA will keep the washers in place.
That's about it. I showed it this way, because as you can see, it can't be seen once it's put together.
It looks like this set is already sold. A good offer can't be refused.
Finished.
Photos:
The reflector was SMO, but it had several rings in it and adjusting didn't help one bit. I made it into my version of an OP reflector, with Krylon Clear.
The 26650 adapter and the modified 3AA holder.
Garage door
Side of house
Across the pond.
This 1C T6 led gives a nice white light and I am starting to favor it over the neutral. The newer version of the KD 8X7135 driver giver more amps and I think it's noticeable. There is a 2nd setting. I bridged for H/M/L, but of course, the paper they sent with it is wrong and I got H/L or H/M
It is what it is.
