Yep, you should be fine. As long as these are decent cells (as in not a shitty little lipo in them) you will be fine. I would still recommend a slower charge rate though.
Read the specs of the battery. If not provided, then this is often safe: quality brand up to 1C, Chinese fire hazard brands up to 0.5C.
I don’t mean advertised C but real C of the battery. For the fire hazard brands you might as well cut their advertised capacity to 50-75% in most cases.
Temperature probe is advised, so you can cut it off when the temperature starts rising.
For the chinese fire hazard do you mean the **fire ones? Will an extra 250mah charging be a hazard for those fire brands if so I’ll invest in better quality ones as I do not want to get another charger.
