$100 Budget Lights w/ OUTRAGEOUS Power: Wurkkos TS32 + Nichia 519a. Comparison to Chinese-LED Heavyweights: Haikelite, Jin Heng JKK76,👍 MULTIPLE Nightwatch's 👍. LATEST: World's brightest EDC-15k lumen 60-buck Nightwatch A54U. (Measure p.1)
MEASUREMENTS
I repeat measurements multiple times and make mistakes, please expect multiple edits in this post to update data as needed.
Lumen numbers posted are the highest value that I got, meaning if I there is a range, I tend to post highest value unless it looks ridiculous strange. Same thing with Duv, “best” values from a range is posted.
Nightwatch Avaritia A54U Version 2 with four 4000k N5-165HPE+
USB-C charging working fine. Review starts here.
CCT : 4000k exact (measured at Turbo level)
CRI : 90 (phew - barely making the 90 cut)
Duv : 0.0048 (Tint snobs among us be quiet & don’t be a party pooper :-).)
Level 1 = 130 lm, 3720k, Duv 0.0020
Level 2 = 530 lm, 3740k, Duv 0.0020
Level 3 = 1150 lm, 3764k, Duv 0.0030
Level 4 = 3290 lm, 3961k, Duv 0.0050
Turbo = 14780 lm, 4000k, Duv 0.0050
Output - Highest of multiple runs with full battery and cool light.
EVE 40PL: 14780
AM04 (JP40 Clone): 13740
Nightwatch Battery 45XP “80A”: 12300
Molicel P45B: 12350
Wurkkos 5000 mAh: ~8000-9000
Brightness levels 1-4: 130-530-1150-3290, moonlight=20
Throw Turbo @ 0 and 30 sec
EVE PL40: 76 Kcd @ 0 sec, 5 Kcd @ 30 sec (dramatic thermal step-down at around 20 sec causes extremely lower 30 sec value)
Wurkkos: 0 sec 49, Kcd 30 sec 14 Kcd
Throw at Turbo-1 level More useful for this light because of dramatic step-down at Turbo.
EVE 40PL w/ Zircon: 14.1 Kcd @ 0 sec, 13.5 Kcd @ 30 sec
EVE 40PL No Zircon: 17. 4 Kcd @ 0 sec, 16.5 Kcd @ 30 sec
PWM Level 1-3 and Turbo have no PWM, level 4 PWM at first then step down to lower level without PWM.
Thermal regulation excellent: Tmax ~41C, Tsustained 40, Sustained output ~900 lm.
Nightwatch Avaritia A54U Ultra Version 1 with four 6500k N5-165HPE+
Some first-generation lights have malfunction onboard USB-C charger-DO NOT USE. It does NOT stop charging at 4.2 v and continues to charge and destroys battery.
Output
AM04 (JP40 Clone): 15000 lm
Nightwatch Battery 45XP “80A”: 14400
Molicel P45B: 14060
Brightness levels 1-4: 120-530-1180-2940, no moonlight
Turbo Throw at 0 and 30 sec: Significant thermal step-down causes significant change among batteries and make measurement difficult.
EVE PL40 Battery: 70 Kcd @ 0 sec, 16 Kcd @ 30 sec
Molicel PB45: 38 Kcd 388m @ 30 sec
Wurkkos Generic Battery: 49 Kcd 443m (lower output but less thermal stepdown hence longer throw)
Throw at level T-1 (more realistic, less dramatic step-down):
18.2 Kcd @ 0 sec, 17.5 Kcd at 30 sec
Duv 0.0000 @ Turbo level
CCT 5900k
Ra=70
Thermal regulation with JP40: Tmax 39°C at 60 sec, T equilibrium 39°C, output at equilibrium approx. 1000 lm.
Thermall regulation with Wurkkos: Tmax 46.5° at 90 sec, T equilibrium 41°C, Output at equilibrium approx. 1000 lm.
PWM: Level 1-3 and Turbo no PWM, level 4 PWM at first then steps down to lower level without PWM.
Nightwatch NS14R v2 Discussion starts HERE
NS14R v2, top 3 readings, batteries fully charged and lights cooled before each run.
AM04-JP40 from 18650-21700.com: 21300 lm (top 3: 21000, 21000, 21300)
EVE 40PL: 21000, 20300, 20800
Nightwatch 45XP “80A”: 20500 (19560, 19570, 20500)
Molicel P45B: 18620 (18240, 18520, 18620)
Lishen LR2170LH: 16980 (16680, 16810, 16980 - old battery)
Samsung 30T: 16840 (16090, 16340, 16840)
Wurkkos 5000 mAh No name: 10800 then the light died, literally :laughing:
NO PWM all levels.
NIGHTWATCH SUPER VALKYRIE N103S With SFP55.2L LED
Brightest single LED, single battery flashlight on the market.
Throw: 676m w/ Nealsgadgets’s Lishen Battery
CRI-Ra 71
CCT 6400
Duv -0.0002 Turbo, 0.0011 Turbo-1, 0.0022 Turbo-2
Duv more negative with higher output.
Output:
Light 1: Lishen LR2170LH Battery from Nealsgadgets 13090 lm
Light 2:
AM04 from 18650-21700: 13340 lm (top 3 readings13020, 13300, 13340)
Molicel P45B: 12960 (12670, 12940, 12960)
Nightwatch 45XP “80A”: 12340 (12270, 12280, 12340)
Lishen LR2170LH: 12330 (12110, 12190, 12330)
Samsung 30T: 11300 (11270, 11270, 11300)
Weights
Nightwatch Chaos 355 gm (492 gm w/ Neal’s Lishen batteries)
Wurkkos TS32 439 gm (651 gm w/ Samsung 40T batteries)
Jin Heng JKK76 496 gm (702 gm w/ Samsung 30T batteries)
Haikelite HK05 511 gm (712 gm w/ Molicel P42A batteries)
Nightwatch NS103S Super Valkyrie 307 gm (402 gm w/ Molicel P42B & battery adapter, 423 gm with QB26800 battery)
Lenses "Green reflection (of ceiling light bulb) is desirable if you like less green beam tint (more negative Duv).
Jin Heng JKK76: Purple Reflection AR
Haikelite HK05: Non AR (no change using ceiling light bulb reflection test)
Wurkkos TS32: Purple Reflection AR
Nightwatch Chaos: Green Reflection AR
Nightwatch Super Valkyrie N103S: Green Reflection AR
WURKKOS TS32:
Throw 702 m Both LEDS, 371m 519a alone, 664m SFT40 alone
Output
Turbo start, highest value for each, from separate runs:
With Wurkkos batteries: 519a=12,700, SFT40=1700:Both LEDs: 13,000
With Samsung 40T batteries: 519a: 13900, SFT40: 1700, Both LEDs: 14900 (range 14000-14900)
With Samsung 30T 519a: about same as 40T ~14000, SFT40: about same as 40T ~1700. Both LEDs: max 15800 lm
Molicel P45B nearly identical result as Samsung 30T
With Samsung 30T & Zircon 1/4 Minus Green: Both LEDs 13190, 519a = 12160, SFT40 =1370. Roughly 15% loss.
CCT, RA, and Duv
Nichia 519a only:
Duv (approximate avg from many repetitive runs)
Turbo –0.0020 to -0.0040
1 level down from Turbo: 0.0020 (range ~0.0030 cold, 0.0015 hot)
Essentially, the Turbo beam is fantastic & more beautiful than beams at lower brightness.
CCT ~5100
Ra ~98
SFT40:
CCT 6100 low output, 6400 high output
JIN HENG JKK76
Output: 22300 lm w/ Molicel P45B, 21600 w/ Samsung 30T
Throw: 773 m w/ Samsung 30T
Ra: 68
CCT: 6100 Turbo, 5808 Turbo-1, 5755 Turbo-2
Duv: 0.0060 Turbo, 0.0087 Turbo –1, 0.0094 Turbo-2
CCT increases and Duv decreases with higher output.
NIGHTWATCH CHAOS
Throw 754m
Output:
Nealsgadgets “Mystery” Lishen “LR2170LH”: 29300 lm
Molicel P45B 26900
Samsung 30T 25800
Samsung 40T 22900
Molicel P42a 22600
Convoy Liitokala 19300
Wurkkos 5000 mAh 18800
Level 1 & 2: + PWM. Level 3, 4, Turbo: No PWM
Ra 67
CCT 5808 Turbo, 5736 Turbo-1, 5529 Turbo-2, 5507 T-3, 5479 T-4
Duv 0.0047 Turbo, 0.0064 Turbo-1, 0.0093 Turbo-2, 0.0097 T-3, 0.0100 T-4
CCT increases and Duv decrease with higher output.
HAIKELITE HK05
Throw: 824m w/ Molicel P42a
Ra 70
CCT 5742 Turbo, 5599 Turbo-1
Duv 0.0084 Turbo, 0.0094 Turbo-1
Output
Output: Samsung 30T 23500 lm
Molicel P42A 20700 lm
CRI-Ra 71
CCT 6400
Output
Output: Nealsgadgets’s Lishen LR2170LH Battery 13090 lm :exploding_head:
PWM lower 3 level, no PWM at Turbo
