In couple of hours after ordering
Check how OSHPark works, you order, they send it to production, when done you get it in the mail, assemble (should not be to hard to do) and you are good to go, you can boost your personal lumens dispenser easily
just follow the link -> http://oshpark.com/shared_projects/Cm0cEnQy
you can buy one of the drjones drivers for momentary switch if you like them and just transfer parts to this board + some additional AMC’s from FT…
Need some work but it is a solution and it is available right now. I doubt that it will be available as kit…
That driver (LD-36?) is not happy running from 4.2v (all 4 cells in parallel). It turns on but makes a wicked squeal. It really needs 2 or more cells in series. It's also not a good choice for running 3 LEDs in parallel as the output current is divided equally between them. It's really only good for running a single LED from 2S or 3S.
Just be patient, as soon as these (and the other direct drive version) are out in the wild, they'll be available ready-to-run.
If you're capable of assembling the bare driver you're more than capable of flashing the MCU yourself. A test clip, USB programmer, Atmel Studio 5 software, and the ability to open a command prompt window and paste a line of commands. You don't need to know how to write the code from scratch, I sure don't.
You don’t even need to flash anything. If you can solder, order a set of boards and just buy a Qlite driver and swap the already flashed IC onto the bigger board and add as many more 7135’s as floats your boat. Or just wait for someone else to get their 3 boards and pay them to to it.
Pm DrJones. He wrote several versions of code for the Attiny IC including e-switch and sells both drivers and mcu only for a very reasonable price. He’s in the EU so it takes a bit longer.
