I want to illogically sink money into a cheap 14500 zoomie that I happen to be modestly impressed with its build quality.
MTN is sold out of 7135 regulated 15mm drivers, and I’m not sure this light can handle a FET (the pill is fairly thin Aluminum).
Are there any other 15mm drivers I should be aware of? At least 1.5A (the driver I’ve currently got is 1.0A; I want more) and single or multi-mode is OK as long as there is NO STROBE.
1A is about max for small boost drivers. A sense resistor mod beyond that is likely to blow either the input diode, the boost IC, or the sense resistor. Rich has the bare boards and parts to assemble a 7135 driver.
If you go that route buy two. If the first one works congratulations. You will need a Qlite spring or 5 mm brass button to clear the bottom side 7135’s even with button top cells.
