Checkout the Fireflies new E12, and the E04 Surge. Or basically any of the FF lights have ultra high CRI 1800k options and they have the best buck/boost drivers.
Not personally but I found a lot of beam-shots and while it does throw far, it also has some pretty strong spill. Normally I’d see this as a feature but not for this particular light.
Nice tint! I have an SFT-40 in a smaller reflector (convoy m21f) and this looks floodier than that. I wish Hank offered smaller emitters with the Lume X1 driver in the K1
Something else to consider might be yellow filtered glasses/lenses. I WANT to say it could be a placebo, but I was using my yellow filters the ither night and it took ALOT of the harshness out of what I was seeing.
The Fireflies E90 series is very throwy but might not be pocketable and if you want smaller pocketable size then try the X1S series that is somewhat throwy. If you want throwy, then you need a big head and the light will not be compact.
Has anyone ever opened this light? I tried everything but couldn’t get the bezel to move.
At least the LHP531 in 1800K is very much amber and not warm white!
I would have thrown the M21B into the ring as well? Got somewhat throwy host, with a 519A and an OP reflector it could be the right light.
I imagine it would reduce backscatter somewhat because of the longer wavelengths. The important thing isn’t solely how much light makes it on target, it’s how much of that light comes back to the eyeballs, so I’m inclined to believe that limiting some frequencies would be similar to cutting back interference noise.
Well, the Google AI overview goes with the longer wavelengths = better theory.
But I found this source that states otherwise:
Interestingly, I accidentally backed away from the search page and reloaded it and this result was missing from the google results despite being at the top before. Weird…
