18650 rechargeable trough USB-C PD directly?
As written in subject. Is there rechargeable 18650 battery with integrated USB C slot and can be charger with normal usb-c to usb-c cable from charger with PD? I tried to find it but So far no luck even tough I could swear that I saw atleast one somewhere. :expressionless:
Just a note, you’re looking for a cell with proper USB-C support, not necessarily PD, Power Delivery allows the use of higher voltage for higher charging power, which would be overkill for charging a 18650 cell, and since it’s more complex it’s very unlikely to be used in a cell with integrated charger.
Edit : Nitecore NL1826RX having powerbank function it should have proper USB-C support
Yeah you are right, I need just to have proper USB-C support, ie. be able to charge it using USB-C to USB-C cable, not USB-A to USB-C as now with my Acebeam 18650 battery the PD is not the matter for me.
