If a flashlight will take a protected 18650 (a 18700) and will also take 3xAAA, then will it necessarily take a 21700?
i tried several of mine and 21700 fit.
Length could be an issue.
I know for sure that somebody will say: but there are programs for it on the net. Aren’t there? Yes there are!
But I am an oldfashioned techie who used to calculate things without an electronic device.
So what size should be the diameter D of a hole where you can put in three (equal sized) smaller cylinders (batteries).
Using a ruler and a pair of compasses I come to: D = d * (1+2/√3) ……or…… D = d * 2.1547
where d is the diameter of the smaller circle/cylinder (the AAA battery measures 10.5mm or 0.41in)
So I’m pretty sure it will fit. (after removing the sleeve
fit fine in my “green ring” zoomie and ultrafire g700 type zoomie.
its tight lengthwise but fits.
Answer for ‘A’ is 10.
18700 + (3x(A^3)) = 21700
21700 - 18700 = 3000
3000 / 3 = 1000
Cube root of 1000 is 10.
Solved :student:
Yep I don’t know what I’m talking about ![]()
ROFLOL!
btw i tried in a hausbell tulip/x700 zoomie and while it works its a bit snug the last thread or so.
i didnt want to crush/dent the cell so i stopped.
o ring is well engaged so no problem not bottoming the tailcap.
