The original substrate uses six-volt LED chips configured in four-parallel connection. To adapt to the custom 3-volt LED emitters from Nightpatroller, I collaborated with several fellow enthusiasts to produce a batch of copper substrates wired in two-parallel-two-series topology. Now the flood-beam section is compatible with all commercially-available 3-V 5050-package LEDs, while the throw-beam section can accommodate quad-die 5050-package LEDs.
could you give some comparision between before-mod and after-mode?
very cool. I have an X1 Pro and it could be interesting to switch the flood emitters to LHP531 and the throw emitter to an SFT70.
Does the throw emitter have to be quad die or could it support an SFT60 or even SFT42R? EDIT, I guess you could just reflow them into the original PCB?
For the throw section, quad‑die LEDs are mandatory for the substrate to wire two dies in series with the other two dies. This allows 3‑V LED dies to be operated at 6 V. No such constraint applies to the flood section, where any commercial 3‑V 5050‑package LED can be used.
Thanks.
Any way of purchasing these?
Uploading: IMG_20260806_213853.jpg…
Uploading: IMG_20260806_213702.jpg…
Uploading: IMG_20260806_213608.jpg…
Uploading: IMG_20260806_164114.jpg…
Currently, the flood section is populated with four Nightpatroller 5165++ LEDs, featuring 45‑mil ×9 die layout. The throw section uses 5350 LEDs with a 55‑mil ×4 die configuration.
Some of my partners may list these for sale on Xianyu. Since this is a group‑buy custom project, each person gets three sets, and some participants will resell their surplus units on Xianyu.
