$25% off Christmas Sale: Nichia 219 Mag 1C with Megnatic Swich Ring
a unique hand made mag that I’ve wanted to put together for quite some time, just wasn’t able to figure out how.
I am never interested in making the same thing twice, so here it is, for the true mag lover, I proudly introduce the one & only, Magnetic control ringed total stealthy mag 1C with Hi CRI Nichia 219.
Mag 2C being cut down to 1C.
Stealthy looking, a wolf under sheep’s skin
Magnetic control ring is sealed & rotate outside the body.
seals better than OE due to removal of clicky boot, the weakest link
Instant access to HI to one direction & instant access to SOS to the other direction
3 mode Hi/Med/Lo on one direction, two blinky mode to the other direction
Tasteful Teardrop separator between modes
One does not need to go through blinky to access Hi/med/lo
Total 360 rotation to go through all 5 modes also possible
Nichia 92 CRI 219 led
Mag Rebel SMO reflector -Spatted to partial OP for better beam
Built-in black Alu battery spacer for 18650
Recessed spring for shorter length
>3hr run time on high with high capacity quality 18650
Asking only $200 shipped Christmas Sale 25% $150 shipped(US only)
Other countries by PM.
Incredible work! Looks totally factory!
Thanks Johnny!
ma-sha1. You are one very clever chap. Very nice.
Thanks!
bump…
Another drop, $129 shipped
Very nice! I'm surprised this is still for sale!
Thanks!
Probably lumens, would have sold it if it’s fully driven XML.
This is more of an indoor light, looking for things inside the house with better CRI, it’s one of the very few light I do actually use, LOL
I just can't get over how gorgeous that light is, ma-sha! Since I can't afford it, can you share details on just how you went about creating it? That is possibly the sweetest custom I've ever seen. :hat:
I joined CPF in 2009 and enjoyed reading your threads there and learning from them. This is such a nice piece of work I’m sure it will sell. It just needs time to find the right buyer.
Sure,
Not much to say, except, l had some budget flashlights with the adjuster ring, one of them looks like a good fit to mag C, both diameter & color scheme. I basically cut out the magnetic ring section & sandwiched inside to the mag C tube & cut out the bottom of the OEM flashlight head & jointed to the bottom of mag C head.
The concept is easy, but it does take some practice, I probably did over a hundred cut & joint type of projects, fairly comfortable now but still took quite a few hours & lots of grinding. Joint the tube is easy, splice & joint two heads together & make it look like one is hard.
The host is a Q5 driven to 1 Amp, bought on ebay a while ago, not sure how to find it again.
The limitation is the driver, which I could not access or upgrade. This limit the out put, that’s why I swapped it out into a Nichia 219, since it can’t compete on hi out put, might as well make it useful. It’s till fairly bright, think McGizmo PDS 1Amp drive level of light, enough for in doors, some time I had to drop a level as it’s too bright for close up.
The reflector is rebel SMO but beam is not perfect, so I sputtered it, gives a better beam but spatter Rebel SMO doesn’t look as pretty as sputter regular mag reflector, non the less, the beam is better.
The only other guys who made a magnetic ring mag is Will, on CPF, however, with a custom neck that’s silver & bigger in diameter, not stealth looking. I am very happy with the look & UI of this light, just that I wish if there are magnetic switch rings available with high out put or swappable driver, would love to make a hi power one but it’s unlikely.
It does look as pretty as what picture shows thou, I am not a collector, otherwise, it’ll be Queen on a mag shelf :slight_smile:
duplication deleted
Price drop to $129
